Does it copy??? try different file different program pdf, web page does it print the demo page does it print the counter page????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Bixhub c351- I can copy in duplex but i can not print in duplex
Have you told the print driver that you have a duplex fitted, also is the paper set as plain as any thick setting will cancel out the duplex function.
SOURCE: adding a new computer to scanning network of konica bizhub c351
Manuals:
http://help.bt.konicaminolta.ca
Utility/Counter button
#1 Create one-touch.
From here make selections until you find the one you want.
or....
Use your Web Browser to log into the device by entering the copier IP Address. From here you can create one-touches as well, and is easier.
SOURCE: i have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
