Precor EFX 576i Experience Series Elliptical / Crosstrainer Logo
A
Anonymous Posted on Apr 29, 2014
If I stop moving, I use to have a delay that said pedal faster. This stopped and now shuts off if I stop and I lose my stats. How do I get the delay back ?
Russ Wolterstorff
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 60 Answers
  • Posted on Jan 10, 2015
Russ Wolterstorff
Contributor
Level 1:
New Friend:
Cheetah:
Answers
60
Questions
0
Helped
43846
Points
66
Does the elevation work? If not, the battery is probably dead. If the elevation works fine, then it may need to be changed in the settings menu.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Delayed response when pressing gas pedal.
This sound like it might be a transmission issue. If the revs are dropping as you are at idle something is 'Dragging' the revs down and the delay is the engine and transmission trying to catch up with each other. A test you could try is the next time the revs start to die drop it into Park and 'Blip' the gas pedal to get the revs up then put it into Drive to pull away.
You may need to take it to a Transmission Specialist to get them to look at it.
Fridge defrosted and the motor seems to have stopped working, electricity working fine to it
Most likely t-stat. If the t-stat is good then move to compressor. If you hear a hum then a click and it shuts off, that is the internal overload telling you the compressor is done and needs to be replaced.
Mar 23, 2014 • Freezers
1993 mazda mx6 wipers delay stop working other speed work stop where ever shut off
Weres the fuse for the wipers I bought the car and the guy said he took out the fuse cuz they won't shut off
My thermostat does not turn off the air handler after the outside compressor shut down. keeps blowing and blowing
There can be a 5 minute delay after the compressor shuts off. But if after say 15 minutes its still going something else is wrong. Verify t-stat is on auto instead of on. move it back and forth to be sure. Then remove t-stat and disconnect the red wire. If shuts off now the problem is in the t-stat (likely a shorted wire or something touching something wrong. rarely a bad t-stat but possible. If furnace still running while red wire is off the t-stat there is a problem at the furnace. open it up and disconnect the red wire from the R terminal. If still running the computer has a bad relay that is stuck on. have to replace computer. If it shuts off there is a short in the t-stat wire such as mice chewing marks a nail in the wire or wire rubbed on sharp metal surface. Find and repair it or replace the t-stat wire. Good luck
How do you properly disengage the 4wd on a 2001 dodge durango
2wd to 4hi to 2wd can be done moving or stopped .. if moving shifts can be made up to 55 mph with the vehicle in motion, the transfer case will engage/disengage faster if you let off the gas pedal after turnin the control knob. if the vehicle is stopped.. the key MUST be in the ON position with it running or OFF the shift cannot be done if the key is in the accessory position
4helpful
Brake pedal gets hard when braking, no normal braking
If there is a malfunction in the brake servo assist system, and your assistance is reduced, the brake pedal will become hard and you will need much more pressure on the brake pedal to stop the car.
It is possible that there is a vacuum leak in the brake servo assist system and you are only getting 50% or less assistance when you are applying the brakes.
You need to have the vehicle checked out without delay because if you lose brake assistance entirely it will be very difficult to stop the car.
My Impalas tires stopped rotating when gas pedal is pushed down.
Could be but you may just be very low on transmission fluid. The proper way to check it will be printed on the dip stick if it's original. Be careful adding your transmission fluid, over filling your transmission can ruin it faster than running it to low on fluid. Between the min and max marks your transmission will take about 1/2 pint.
2answers
Honda Accord Saloon 2001 Windscreen Wipers : Intermittent wipe no longer works - Goes on to normal wipe Wipers do not stop when shut down. - Require to turn off ignition to stop them
2 things.
1 bad connections on the motor itself under the skuttle panel below the window screen.
2 the stalk from the steering wheel is broken, they have small metal parts inside they sometimes come lose and stop working, just replace it.
Car began to lose power while on freeway then stopped
Sounds like the alternator is going bad and killing the battery.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
