Try it.......
Remove the print head and soak it for three 5-minute cycles in hot
(~170 F) distilled water about 3/4 inch deep with continuous mild
agitation. The first soak quickly turn the water black, the second
end with the water a dark grey color. The hot distilled water dissolved the dried ink in the small ink
passages from the cartridges to the ink ejection part of the print
head.
Carefully dry the print head as per instructions, clean the
electrical contacts on the printer, and placed the print head and the
ink cartridges in the printer.Turn off the printer, then unplugged it for one minute.Then turn it on...and print an alignment sheet...
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
