Sharp Atomic Weather Station Alarm Clock Logo
A
Anonymous Posted on Apr 28, 2014
I received a Sharp spc595 weather station. I need an outside unit the sends in the outside temperature. Where can I obtain one plus a service manual for the weathere station? I live in Denver, CO
1 Related Answer
lety pryntesyka
  • 4 Answers
  • Posted on Sep 10, 2013
SOURCE: I can't adjust the time zone on my Sharp weather
[email protected]
2answers
I need a outdoor sensor for a sharp weather station 595
I'm seeing that product/brand on ebay and amazon, so you can reach out to sellers of the item on those websites and they should have the accessories that you need.
Thank you.
1helpful
AcuRite Professional Weather Center 01602BPDI. It eats the outside batteries. Batteries last about 2-3 months till low battery power shows inside with -40 degrees plus other false readings.
My National Geographic Weather Station is the opposite. The outside sensor only indicates the temperature, but the single CR2023 battery lasts a year. The inside unit on my desk lasts around 5 - 6 months and lets me know if needs a battery by showing the outside temperature as ' -- '
Although the manual says 'rechargeable batteries are not recommended', I would try 4 Sanyo Eneloop batteries. Or you could contact Acurite Support and ask them if your battery use is excessive?
01602BPDI - Professional Weather Station Instructions
AcuRite.com https://www.acurite.com > 01602-instructions
Professional Weather Center model 01602BPDI. Questions? Contact Customer Support at. (877) 221-1252 or visit www.AcuRite.com. SAVE THIS MANUAL FOR FUTURE ...
1helpful
2answers
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
48helpful
How do i set time zone on sharp weather station pcs775
On the SPC595, there were no specific instructions to set time zone, either (default was Pacific, I'm in Eastern), so I'm hoping that what worked on this will work on your unit:
Try hitting the "UP arrow" when the clock is NOT in a setting mode. This is not referenced in any "setting time" area but rather the area of the instructions that tells you what each button does. My manual (if you can call it that) says the following:
"UP Button
In setting mode, press it to increase the setting value. Press it to switch the time zone P/M/C/E"
Top Sharp Measuring Tools & Sensors Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Measuring Tool and Sensor Expert? Answer questions, earn points and help others
