Hook up external speakers using Onkyo Digital Receiver, not surround sound
SOURCE: connecting lg tv to two external speakers
Yes,
depending on how many speaker you intend to run will determine the type of amp you will need. Set the output on the source unit to optical out. Connect the optical cable to the amp. Connect the speakers to amp. turn them all on and select the iput of the source unit on the amp and enjoy.
good luck
chachig
SOURCE: LG tv sound quit - will it work if I add external speaker system
Maybe!! It depends on where the audio sys failed. If it failed at the output drive, then you can take the audio off at the audio output jack and input it to your stereo system where there is an audio input. You'll need a cable with RCA jacks on it for this.
If your system is muted for some reason, this may not work.
SOURCE: I just bought a LG 55le5400 TV. How do I hook up a
You can use rca cables to hook it up or use the toss link cable if your receiver has that.
Dirty Connections Dust plays Havok with those connectors go to Radio Shack and pick up a Can of Contact Cleaner Spay both the Jacks and The cables
SOURCE: DOES LG 37" MODEL # 37LB4DS-UA.AUSLLJM HAVE A HEAD PHONE JACK
On the back of the tv and the cable box should be red, white and yellow rca jack, the white and yellow are sound
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
