The PMD520 doesn't have balanced XLR inputs; only unbalanced phono/RCAs. If your source has phono outs too, then use those, because the benefit of balances inputs is lost when converted to phono.
If you still want to go ahead, then buy some balanced to unbalanced converters.
Studiospares RED502 Bi Directional Balanced Unbalanced Converter
If you try to do this on the cheap by wiring an XLR to phono, be aware that the studio level output of balanced level connections is about 2V rms. The live input level for unbalanced is around 1V rms. You'll either need to pad the input to reduce the level or run the cassette REC level controls nearer to the bottom of their adjustment range where they're a bit noisier and not so linear.
