The freezer does not freeze and the refrigerator does not get cold. The fan runs though.
SOURCE: Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement. Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect. If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply. Thank you.
SOURCE: freezer cold, fridge warm
SOURCE: my refrigerator freezer and ice box are not cold.
compressor not running or defrost system not working.
SOURCE: my refrigerator haier hte21waaww doesn't work, just the frezzer,
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem.
2...Check your thermostat and make sure it is on the colder setting.
I hope this helped you,
Please rate me...Thanks
Hi, Thank you for contacting fixya.com. Check the coils on the rear of
the refrigerator and make sure they are clean and dust free. Also check the
back wall or floor of the freezer section for frost. Check the evaporator fan
to see if it is running. Check the condenser coils under the unit for blockage
from dust. Check the condenser fan under the unit to see if it is running. If
you have frost in the freezer there is a problem with the defrost system and
the freezer will start to warm eventually as well as the fresh food section. If
that is the problem you can check the defrost terminator, defrost heater/s, and
the defrost timer or adaptive defrost control If used on your unit or the main
control board if so equipped. Also check the freezer to ensure it isn't over
loaded with food stuff, reason being air must flow freely threw out the entire
refrigerator in order for the thermostat to work correctly. Defrost the freezer by
disconnecting the power to the refrigerator and letting it sit for at least 24
hours with both the doors open to allow the frost to melt completely but it
will build up again in 1-2 weeks and start the warming up again. Please get back to us if you have further query else please accept
the suggestion.
