Kenmore Top Freezer Refrigerator Logo
A
Anonymous Posted on Apr 28, 2014
How do i open back panel for kenmore model 106.64232402?
Daily there has been a puddle of water on floor but we do NOT have water hooked up. How to fix?? Kenmore fridge model 596.72003014 with bottom freezer
In the back of the freezer, very back. Behind the panel or at bottom under panel (some models you can see it without taking panel off) you will see a drain hole. Its frozen over. 2 ways to fix it.
1. Take Panel off if u can't see the drain and then pour hot water down until it opens. (Get towels).
2. Unplug fridge and open doors for 72 hours minimum. It will defrost itself.
How do you open up the kenmore dryer model 80311900 with the front control panel for cleaning out lint
To disassemble the machine, disconnect the power!
I believe that model has two screws in the rear edge of the top panel. Remove the screws and slide the top panel to the rear and remove it. Then remove two screws, from inside the machine, that hold the front panel in place from the back. Label the wires, then disconnect them. Tilt the front panel forward, then lift the bottom of the front panel up.
7helpful
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Why won't the Kenmore top loading washing machine agitate?
There are two types of Kenmore top loading washing machines. The direct drive models and the belt drive models. Direct drive models do not have a back access panel and the water inlet valve is located on the left side viewed from the rear while belt drive models do have back access panel and the water inlet valve is located on the right side viewed from the rear.
The most common problem causing a top loading machine not to agitate, particularly when the motor seems running, is a broken motor coupler for direct drive models and a broken or worn out drive belt for belt drive models.
The best way to exactly determine the cause is to access the drive motor. Open the back access panel for belt drive models and check the drive belt. Check the drive motor if it is running, humming or stuck.
Please indicate the model number of the washing machine if it is a direct drive model for the procedure in accessing drive motor.
2answers
Kenmore Elite refrigerator not cooling
no no put it back to normal setting!!! now is the freezer side cold? if it is cold you need to open it give me your model # and i help you [email protected]
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
