Question about Lanier Office Equipment & Supplies
Formatting Hard Drives on Lanier copiers. - Lanier Office Equipment & Supplies
    Champion:
  • Lanier Expert
  • 208 Answers
SP Mode 5832-001
Posted on Dec 14, 2014
SOURCE:
  • 904 Answers
SOURCE: How do i empty a waste toner bottle on a lanier
What kind of copier is it? On many of the Lanier color copiers, the waste toner bottle is located on the lower left side inside the front door.
Turn the copier off first. Pull the big front door open and turn the bottle with the oil to the left -- the waste toner bottle is the plastic gray tank behind that. Slide it out (carefully) and dump it in a plastic trash bag, then reinsert it.
If you have a different kind of copier, please specify the model and I'll tell you how to get to the waste toner bottle.
Posted on Jul 18, 2010
  • 121 Answers
SOURCE: Lanier Copier User Manual
Go on line to Lanier.com, chose manuals. Then put your model in and that you want the users manual and down load it. Most of these kind of manuals are free to copy.
Posted on Oct 17, 2007
  • 11 Answers
SOURCE: COPIER
I think there is a cover on the back that you have to remove
Posted on Dec 27, 2007
Cogz
  • 1326 Answers
SOURCE: lanier 7213
Is the copier displaying any numbers or letters besides a service call light. The copier will display more then you are telling. Need a little more info. to give a educated answer or do you want a SWAG answer?
Posted on Mar 12, 2008
Cogz
  • 1326 Answers
SOURCE: Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Posted on Apr 06, 2009
How do I Remove the hard drive from Lanier printer model number LD445C
It is located behind the panel where your Ethernet cable plugs in. The easiest way is to remove the rear panel. Then remove the metal panel. From there you should be alright on your own.
Oct 14, 2014 | Ricoh Lanier Ld445c Ld435c Ld430c Magenta...
Lanier 5618 Network
Lanier 5618 is not a Network Copier. However, it may be installed on one PC and shared from there. Drivers are available from LANIER Official Support
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 22, 2011 | Lanier 1205 Copier
We have a Lanier Copier Model 5635 and we need to know if saves PII information on a hard drive before we can remove it from our office.
yes it does. the hard drive is located on the left side in back of the machine, It is easy to remove. If you are trading it out, you can either remove it yourself or have a service rep remove it.
I have done that several times for customers who do not or can not allow hard drives to leave their presence.
Feb 22, 2011 | Ricoh FT5832 Copier
How do you remove the hard drive (memory) from a Lanier model 5635 copier?
FT 5832 is analog copier their is no hard drive for analog it just present digital copier.
Jan 07, 2011 | Ricoh FT5832 Copier
How do I remove the hard drive from a Lanier LD328c. This needs to be done for security reasons.
You should contact a Lanier or Ricoh service technician to remove the hard drives for you, but if you have to do it yourself the hard drives can be removed by unscrewing and sliding out the controller board (on the right side of the copier). The hard drives are connected to the controller board by three screws and four connectors.
Sep 23, 2010 | Lanier UNKNOWN
Lanier ld045 hard drive problem, what does this mean and how do you fix it?
How do you know you have a Hard drive problem? and if you actually do, then replace it. It's just a regular IDE hard drive
Dec 05, 2009 | Lanier Office Equipment & Supplies
Lanier ld 228c says printing will begin after warm up, but it never warms up. Tech says hard drives are bad and need replaced. he put new ones in but still did not correct problem.
Check and measurement the fuser unit components(heater lamp,thermistors and thermalswitch) and check the toner quantity in the copier.If not toner the machine not start to working.
Oct 02, 2009 | Office Equipment & Supplies
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
Lanier 7320 error message c-41 can someone tell me whats wrong
I believe c-41 is a fuser problem. A trained copier tech may be required to troubleshoot.
Mar 19, 2009 | Lanier 1205 Copier
Lanier copier 7313 AG
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Sep 18, 2008 | Lanier 1205 Copier
115 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
