2004 Honda Odyssey Logo
Posted on Jun 21, 2009
2004 honda odyssey radio code glove box number is 11210950
auto builder
Level 1:
  • Contributor 58 Answers
  • Posted on Aug 12, 2009
auto builder
Contributor
Level 1:
Answers
58
Questions
0
Helped
45282
Points
91
The radio code is a series of only 5 numbers. The van had 3 copies of this code and the dealer probably placed one of them somewhere inside or on the owners manual.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 03, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
9118
Points
34
Thta is the serial number for radio i checked for the code cause i work for dealer the radio code is 13426
How to reset your radio for honda oddessy 2004
There is a 5 digit code on a white sticker as you open your glove box. Use the radios preset buttons to enter the code. You will have 10 trys to enter the code correctly
2004 honda odyssey radio code glove box number is 11190493 What is My code ?
with the ignition on and the radiopower off,you have to hold down the 1 and 6 buttons on the radio.hold them and turn on the radio power. 2 series of 4 digits will show. call a honda dealer with the 2 sets of numbers,and they will give you the radio code. sorry i do not reply.
2answers
Radio code
look for a sticker on the side of the glove box lid if there is a 5-6 digit number enter that
4helpful
2answers
Today the Starter for my Honda Odyssey 2000 was replaced and the radio is reading "Code 02". What is the code to unlock the radio.
Each radio has its own unique code yous should be on a card in your glove box or in the owners manual if it is not there your local Honda dealer can get you the code but they need the serial number off the radio and if you did not buy it from them you may need proof of ownership.
1helpful
2004 honda odessey radio code
Need to reenter the radio code, it's normally located in the glove box or behind the radio itself, once found you should have about 3 tries to enter the code, if more attempts are needed, disconnect the neg battery cable for 5 minutes and retry.
2answers
I have a odyssey honda 05 and the radio need a code nobody can tell my my code. My vin # is 5FNRL38465B400693
with the 1 and 6 held down on your presets turn on your radio and it should display your serial number to your radio write all that down and call your honda dealership then you should be able to get your code
also try looking under the ash tray in your vehicle by pulling it out cause some companies put the code there
14helpful
5answers
I need radio code for honda odyssey 2004
my code was on the inside of the glove compartment
3answers
Code radio
Most Honda dealer will give you the code for free. You just need to pull out the radio and get the model number and Serial number. Drive to the neareast Honda dealer ship.
4answers
COde Error 2004 Honda Odyssey, what's the code-don't have the manual
The only way to get the code is giving the serial number off the radio to the loacl Honda dealer. They can then look it up through Honda's radio code database. If you remove the radio yourself, they might not charge to give you the code.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
