Question about KitchenAid KCMS145J Microwave Oven
Rust in the ceiling, corners of microwave; also on the door
There is rust on the corners and the ceiling of the interior of the oven. I read someone recommend a microwave interior paint (part 277) which is only $8.50. Is it safe to spray paint? Wont the paint get into the food just like I am afraid the rust is being lasered down into the food I am heating?
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
Using paint designed for a microwave oven cavity is the only type of paint you should use. If there is rust near the corners, however, it may have become dangerous to operate due to possible microwave leakage.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on Apr 24, 2016
    President:
  • 3,433 Answers
Why is it rusting?
Posted on Jun 21, 2009
SOURCE:
Can I repaint the rust parts in the bottom of the micro wave oven and what kind of paint can be used?
Hello -
Yes the rusted areas inside a microwave oven can be repainted.
First, you will need appliance paint which is designated for microwave interior use. Check with your local hardware store or local home improvements store to find out what paints they sell which fit the criteria for "microwave cavity paint."
You can read directions for how to go about the project:
https://www.doityourself.com/stry/how-to-repaint-the-inside-of-a-microwave
Read the instructions through, completely, before starting on your project so you know what supplies you need to have available and what steps need to be followed before starting.
Best wishes.
Jul 01, 2018 | In Microwave Ovens
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
I have rust like streaks inside my Whirlpool Microwave Door Panel. It is unsigthly. How do I get rid of the rust-like streaks?
Disassembling the door is a major pain and the streaks will likely only be faded not removed completely. Best solution is replace the door. Otherwise taking it apart(and not damaging it) is your only option.
Eric
May 19, 2010 | Whirlpool MH1140XM Microwave Oven
Our 5 year old oven's interior surface appears to
call kitchenaid and complain they might fix it under warranty or replace the unit,, or possibly heard of this and have a fix i persoonally never heard about it good luck mate
Apr 10, 2010 | KitchenAid KCMS145J Microwave Oven
Microwave safety after repainting
Too generic...Did you use the high-temp appliance enamel recommended, or a spray...or worse?
Was the rust inside where it can contact food through the circulating air, or on the outer body?
First thought based on how I read the question: Never use that machine again...but that's based on the word "in" instead of "on my microwave".
If the rust was around the door frame, outside the seals, and you used an enamel (of course) then you may be OK...but...
Considering the fact that a cheap microwave is a drop in the bucket when compared to your family's health...Why risk it?
Mar 29, 2010 | Welbilt MR622W Microwave Oven
Ge jvm1542bf001 has rust discoloration on glass part of door. Took door off, removed handle. Is there a way to access the inner surface to rid grid of rust?
It would appear that no one knows how tofix this problem. I have the same problem and the only sugestions I get is to replace the door.
Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
What causes rust on the inside ceiling of a microwave oven? Can cooking methamphetamine drug in the microwave do that?
Any chemical that is corrosive can cause this, so yes it could be from drugs. Discard right away.
Jul 26, 2009 | Microwave Ovens
Rust inside the microwave oven
This is just okay but if you're quite doubtful you may bring this to any appliance service center for repaint
May 15, 2009 | KitchenAid KCMS145J Microwave Oven
Bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Signs of burning on inside of plastic door surround .
replace plastic inner and check any rust is there, check inside body and compleat door.
Nov 12, 2007 | Bosch HMT9626GB Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
1,435 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
