Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack Logo
A
Anonymous Posted on Apr 28, 2014
How do i remove the battery pack from my go go traveller
My Aeiomed CPAP is broken it should still be under warranty but i cannot contact the manufacturer. Ideas? Please help!
  1. CPAP Supplies & Machines - AmericareCPAP.com‎
    Adwww.americarecpap.com/Supplies‎CPAP Supplies
  2. Insurance for CPAP
  3. CarePlus Program
Search Results
    CPAP.com - AEIOmed Everest 2 Travel CPAP Machine
    www.cpap.com/.../evo-AEIOMed-Everest-2-Travel-CPAP-Machine.html
    Rating: 4.7 - ‎202 reviews
    The AEIOmed Everest 2 is rugged enough for travel, small enough to be ... hh andbattery pack; Aeiomed Everest 2 HH Battery; aura cpap battery powered ruler ...Missing: rto
    CPAP.com - AEIOmed Everest Rechargeable Battery Pack
    www.cpap.com/.../Evo-AEIOMed-Everest-Rechargeable-Battery-Pack.ht...
    Rating: 4.8 - ‎86 reviews
    Complete your AEIOmed Everest CPAP System with the battery pack that frees you from ... AEIOmed Everest 2 Travel CPAP Machine; Everest Aura Travel CPAP ...
I got my battery pack off my Gogo Traveller Elite scooter. But the batteries are encased in plastic and I don't see a way to get them out. Help?
Turn the battery pack up side down and you will see holes around the outside of the case. With a long (12") Philips screw driver, remove 8-10 screws. carefully turn the pack back on it feet and the lid will come off. Be careful with the wires inside the battery pack and make a note of where they go.
1helpful
Battery stuck on Pride mobility scooter
Hi. There are no locking devices on the GoGo Elite Traveller series of scooter. The Battery pack simply lifts off. However, they can be very tight and sometimes require a sharp tug upwards to remove them.
Hope this helps.
2helpful
My father-in-laws gogo will be not used for several months while he's in florida. how should the battery be stored/charged while not in use?
Charge the batteries fully and remove the battery pack from the scooter. About once a month charge the battery pack. It shouldn't take long to charge since you are not using the scooter Don't overcharge when the light on the charger turns green turn it off and unplug it from the battery pack. This should keep the batteries fully charged and fresh when FIL gets back home. Hope this helps you
1helpful
2answers
I have a pride go go elite traveller 4 and need some new batteries, but what batteries and connection am i looking for?
Rachel you need 2 12/12AH batteries that are located in the battery pack under the seat. Simply pull the battery pack from the scooter and with a standard phillips screwdriver remove the many screws attaching the battery pack together (simply turn the pack over to get to the screws) There will be two wire on each battery and also a heat sensor attached to the side of one battery remove the wires from each battery and carefully reove the heat sensor. You can bring one of the batterys to your local battery warehouse type store or a provider and purchase 2 new ones reinstall like you removed attaching red wire to red terminals and black to black terminals and reattach the heat sensor to the side of one battery (you can use packaging tape to reattach). replace all the screws to put the case back together and reinstall in your scooter. Charge the batteries with you charger until the charge light is green then happy riding HOPE THIS HELPS
1helpful
Unable to remove battery pack....I know it snaps in, but is there a release button somewhere that I'm not seeing? Thanks
These battery packs are general held in place with velcro. Just pull up and it should come out. You will hear the velcro snapping as you pull up on it. Make sure you line it up properly when you install it. The battery contacts must be touching one another
5helpful
2answers
Where and how do I replace my battery for my pride gogo ultra travel scooter
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY!
Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
