When I power up my laptop it goes to the logo screen and load up fast then it goes to a black screen then right back to the logo screen. It just keeps doing this. Its not giving me a error screen or the option to start it in safe mode. How can I fix this? Do I need to reinstall windows 7?
Try removing one of your memory chip then boot and see what happens sometime memory goes bad and can cause a constant reboot over and over me know if that help
You might like to Power it off completely by removing the Battery for a few seconds.
If that doesn't help, try booting from your Win7 Installation Disk.
SOURCE: error loading operating system
There is an error on your hard drive. Do an operating system repair.
SOURCE: Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
SOURCE: Windows Error Recovery
Try booting with the disk that came with the computer and start over with a fresh install of windows
SOURCE: Black Screen Dell 600 Laptop
The display drivers maybe corrupt.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the Dell support website.
If it still won't display in normal mode please post back.
Good luck.
SOURCE: Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
