SOURCE: HP LaserJet 1012 Printer prints ghost images
A new toner cartridge solved the problem entirely.
SOURCE: Print SelfTest page
It should be able to print one:
1: try pressing and holding the button for 4+ seconds
2: power off ... press and hold the button while powering on and wait until it prints the test page.
Hope this helps!
SOURCE: HP Laserjet 1012 printing just black pages
in the software there should be an option to "clean heads"
if you click on it it will print a test page off.
it should work better.
SOURCE: hp laserjet 1012 printing black pages
dark background usually means the High Voltage Power Supply is malfunctioning.
replacement only.
SOURCE: hp 1012 won't even print a test page. cartridge
first disconnect the unit from the computer then reset it on your computer go to control panel and add remove files and click on your printer file and select updat/repair but not remove and that will reload your software. reboot and connect your printer and start the test..that may over power the problem, if not try to reload just the driver
1.Position the printer near your wireless network's router. Plug an Ethernet cable into the Ethernet port on the back end of the printer. Run the other end to any of the numbered ports on the back side of the router. Press the "Print Report Page" button on the printer.
2.Navigate to the setup page listed on the report page and click the tab labeled "Networking."
3.Scroll to the "Connections" heading and click "Wireless." Navigate to the tab labeled "Wireless Setup." Click the "Start Wizard" button.
4. Follow the prompts to connect the HP 1012 to your wireless network. Click "Finish" and close the browser.
5.Open the "Start" menu and navigate to "Network." Choose the "Add a Printer" option. Click "Add a network printer."
6. Click "HP Laserjet 1012" and choose "Next" and "Finish" to access the printer through your computer's wireless connection. Repeat the process of adding the printer on any other computers on the wireless network.
Please follow these steps and let me know if it works or not
