SOURCE: u051 error showing / Will not accept ink
when the message appears, hold the reset button for about 5 seconds, this disables ink monitor on most canon models
SOURCE: HP Photosmart 3310 all in way Error Ink System had Failed 0xc18a0101
I had this same exact problem. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
After
I did this my printer reconfigured like it used to do and it was like
it was new again.... well new plus a headache a managed to get while
reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
SOURCE: Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
SOURCE: MP560 Canon Printer Error 6C10
The above suggestion worked short term, but in about a couple of hours, I'd get the same old error code again. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
Don't know if you've found an answer to this problem yet, but I had the same issue for about three months. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
For months, I've had to power off, disconnect from computer, and power on again to kick-start the printing. It was driving me crazy. So far, "pineworks" solution has been a permanent one. Been about a week and have had no problems yet.
SOURCE: error code 0xc05d1381 Ink system Failure on my HP
error message 0cx05d1381, ink system failure. I shut it down and restarted it. same error msg. ??
