Question about Leeson Reversible Electric Motor 1/2 Hp, 3450 Rpm
3450rpm motor how to check the over load swich
  • 34 Answers
MOTOR SHOULD HAVE A RESET BUTTON.
IF U CAN FIND IT, HOLD IT IN-IF MOTOR RUNS
RESET MAY HAVE TO BE REPLACED.MAKE
SURE MOTOR DOES NOT OVERHEAT UNDER
LOAD-THIS MIGHT BE THE PROBLEM.
Posted on Jun 21, 2009
SOURCE:
Baldor motor wiring diagrams
The diagram is almost always either on a label on the side of the motor or on a label inside the little connection hatch.
Jul 26, 2014 | Baldor 7.5hp 3450RPM 213T Frame ODP...
I just installed a us pool pump motor eb841 1hp 3450rpm 208volt 56y and it is leaking water behind the square bell housing actually leaking bottom side of motor
There is a leaky water seal on the pump shaft housing between the pump and the motor.
The drain hole prevents water from going into the motor and this seal needs to be replaced before the motor is damaged.
Aug 19, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
My pump hums for a few minutes and then quits altogether.
This is a classic sign that it is miswired. Check to make sure wether you are using 110 or 220 wiring and then verify how the motor is wired. If this is an existing motor, you probably are getting moisture to the motor. Not a good thing. Replacing the pump shaft seal may do the trick, however you'll want to check the motor for any other obvious signs.
Apr 21, 2011 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
There is not a point setting for air compressors. The pressure switch can be adjusted. Remove the cover from the pressure switch. Adjust the nut tighter for a higher cut off pressure or looser for a lower cut off pressure. It sounds like the compressor is trying tostart under load. If the unloader valve is not working, the compressor will draw excess amperage and do what you describe. The unloader valve releases the pressure in the cylinder at the end of the run cycle so the compressor can start the next run cycle under no load.
May 14, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
High speed spa pump shuts off
Pump speed Selector Switch Contact Probably Missing, Checkout
Feb 01, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Leeson Reversible Electric Motor 1/2 Hp, 3450 Rpm Logo
101 people viewed this question
Top Leeson Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Leeson Tool and Hardware - Other Expert? Answer questions, earn points and help others
