Coleman Cable Twin-Tube Fluorescent Lantern Coleman Cable Logo
A
Anonymous Posted on Apr 28, 2014
Where buy ETU HS s11w 6500k Tube Fluorescent?
Replacement tube
Abraham
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 15, 2014
Abraham
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7151
Points
10
Hi Alex...
The most trusted site is amazon (for buying parts and items), so I have found this Amazon com 11w 6500k Tube Fluorescent
take a look, and see which one fits. enjoy
Simon
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 10, 2014
Simon
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8774
Points
6
Definitely on amazon (because of pricing, fast and secure delivery etc..)
click on the link and pick one
have a nice day
Roger
Level 1:
New Friend:
  • Posted on Nov 19, 2014
Roger
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7151
Points
5
Amazon of course... click on this link Amazon com 6500k Tube Fluorescent and pick one
I hope I have helped..
Replaced the Florescent and Starter on G10Q Circular T9 Globe. Still not working.
Are you sure the replacement tube is a good one? If it had a shaking in transit it could be internally damaged.
There is two basic circuits; one uses an electronic inverter to produce the high voltage necessary to ionise the gas in the tube and the other uses a choke and starter.
The lamp has a heating filament and a cathode at each end. The starter closes a series circuit that includes the choke, starter and filaments. The filaments will glow and heat the cathodes for a predetermined time when the starter will break the circuit and the sudden collapse of the magnetic field in the choke produces the high striking voltage necessary to ionise the gas in the tube. Once a current flow through the tube is established the choke limits the peak current.
Troubleshooting a conventional fluorescent lamp circuit usually begins with testing the tube filaments for continuity and working back through the circuit...
https://www.google.com/search?q=fluorescent+light+circuit+diagram&rlz=1C1CAFB_enGB673GB676&oq=fluorescent+light+circuit&aqs=chrome.1.69i57j0l5.21668j0j8&sourceid=chrome&ie=UTF-8
Where can a buy a new bulb? ETU-HS S11W 6500K . Home Depot?
you can get them at home depot, Lowe's or amazon. If the color is to hard try a 3500 4000 k color temp
Sep 26, 2018 • Dryers
Fluorescent lamp PL 9W 6500K (4pins) I ma looking for the fluorescent lamp for my Coleman rechargeable lantern
you can buy or order this from any store that sells coleman stuff... or online from coleman ...
On a 4 2x2 fluorescent. The inverter shots up wen turning them on and a alarm and red light come on.
Using portable power for a fluorescent light - Photo.net Lighting ...
photo.net > ... > Lighting Equipment and Techniques > Fluorescent lights
Jun 13, 2009 - 8 posts - ‎4 authors
so from a 12 volt battery, the inverter will take something like 20 to ... tube is ignited, it has a quite high current consumption (except when ... I considered the initial start up for fluorescent lamps and I'd certainly power this light up slowly! ... devices, and are insanely sensitive to the waveform powering them.
How To Shoot With Fluorescent Tube Lighting - Envato ...
photography.tutsplus.com/.../how-to-shoot-with-fluorescent-tube-lightin...
Sep 23, 2010 - I just mean, you should plug your lights in and let them run for several... For this shot, I simply set up the weight on a neutral-colored platform with a ... The long shape of the fluorescent tube when lighting a long curved ... Turn Captions On ...tungsten that you can get an inverter and power these off batteries.
Under-counter fluorescent light wont turn on without multiple attempts and then turns off spontaneously after a bit.
If it is really a bulb not a tube, the starter is usually part of the bulb base. Starters don't do anything once the fluorescent tube (a bulb is just a coiled up tube) is lit and running.
https://upload.wikimedia.org/wikipedia/commons/c/c3/Compact-Fluorescent-Bulb.jpg
With those symptoms I'd say Ray is correct, both need replacing.
2answers
How to retrofit fluorescent tube with led tube lights
Note:
First, corrosive or solubility chemicals will destroy the protective shell of lamps.
Second, the normal ambient temperature is -20 ° C to 40 ° C, if beyond the scope of this provision, it will make adversely affect on the lifespan of the product.
Third, before installing, do not connect high-voltage power supply, if there is damage to the external of lamp, switching to the engineers with qualifications for the repair and replacement; otherwise,the bulbs can not be replaced; take care of the the discharge of fire and shock.
Replacement Procedures Information:
First, the LED tube is generally a double-ended conductive LED lamp containing professionally designed built-in power supply, which can be directly input voltage AC100-240V,it can be mounted directly on a dedicated LED T8 tube light shelves, do not need to add other drives.
Second, the LED tube can directly replace fluorescent tubes, the user can remove the original fluorescent tubes and install LED tube, then double-check the configuration of lighthouse, following the figure A, B, C three installation diagram for installation.
Third, cut off the power for the installation, repair, maintenance and demolition work to avoid accidents.
Installation Guide:
led-tube-light-installation-instruction.jpgA, connect the power cord on the lighthouse to the external power lines, no need to distinguish neutral wire and line of fire fit with LED lamps , then rotate 90 °,then connect the power to light up.
B, if there is starter on light house , take out the starter, then just repeat the A
For more information about LED tube,just visit www.ledclan.com
5helpful
10helpful
4answers
How to replace a fluorescent starter
Although newer fluorescent fixtures have built-in starters or no starters at all, most older lights have an easy-to-change, visible starter. It is a small, silvery cylinder that plugs into one of the tube holders. 1) Shut off the switch. 2) Remove the tube. 3) Give the starter a quarter-turn in a clockwise direction, and pull it out. 4) Plug in new starter, giving it a quarter turn counterclockwise. 5) Replace tube. 6) Turn the switch on.
1helpful
When to replace
Inside a fluorescent light, electricity is delivered to a ballast, which sends a spark through the mercury-vapor-filled tube (or bulb), creating light by activating phosphors that coat the inside of the tube. If any of the components are faulty, the light won't work right. Once you pinpoint the problem, most fixes are very easy. Remember to turn off the power first! Old bulbs blink off and on just before they die; repairs are often simply a matter of replacing the tube or bulb. This problem may also be occurring because of poor contact between the pins at the ends of a tube and the tube holders. If the pins are bent, use needle-nose pliers to straighten them. Clean up the pins and socket contacts with fine sandpaper, and brush away residue. Though gray bands at the ends of tube are normal, black bands indicate that the tube needs to be replaced. If only one end is dark, turn the bulb end-for-end. If the tube is new and these fixes don't work, you may have to replace the starter or ballast. Some fixtures ("A-rated") are quieter than others are, but most fluorescent lights have a slight hum. If the sound seems too loud-- or if you can smell electrical burning-- shut off the power. The ballast is probably either the wrong type, improperly installed, or defective. Replace it or call an electrician. Brand new tubes tend to flicker, as do bulbs that are cold. If an old tube still flickers after it has had a chance to warm up (or after you've warmed up the room), rotate it a couple of times in the tube holders. Try cleaning the tube's end pins. If it still doesn't work, replace it. If only the ends of the tube glow, either the starter or the ballast is defective. Replace the starter, then the ballast.
Top Coleman Cable Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Coleman Cable Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
