Sears Vacuum Shredder Bagger Replacement Bag.806008 Logo
A
Anonymous Posted on Apr 27, 2014
Craftsmen 24" tiller pull start doesn't engage?
Dave Vuckovich
Level 2:
Sergeant:
  • Expert 458 Answers
  • Posted on Apr 22, 2016
Dave Vuckovich
Expert
Level 2:
Sergeant:
Answers
458
Questions
0
Helped
106437
Points
620
I would first pull off the recoil assembly and clean out the assembly. There should be something in the recoil assembly that should pop out and engage the motor when pulled. Lube/flush that with some light spray lube.
1helpful
I have a f22o honda rotor tiller.it runs great but when i put the unit in dirt it won't spin.it will if it's not touching anything.
You probably have a belt drive that has is not tight enough to pull under a load. The belt is pulled by an idler pulley that engages when you start the tines. Check the belts by working you engage lever and look for the belt and idler. More than likely there is an adjustment that will allow you to put more tension on the belt thus making it till. Do not do this when the machine is running! The belt should not have flex in it when engaged. It may a little effort to engage the tines when you get it tight enough to till.
Col. Dana Gillespie
How do you rewind a chute turn cable for a Craftsmen Snow Thrower 1150?
Need to know what cable you are asking about. Is it the starting cord for pull starting the engine or one of the auger or drive control cables ??
Can you post a picture ??
May 18, 2014 • Garden
Starting issue
the starter gear inside the pull cord is not engaging
this is a non servicable part
approach supplier and buy a new pull starter
Drive Engages Hard From New To The Point The Arm Is Bending And Can't Get It Up High Enough To Engage It Into Reverse. It Also Pulles Hard The Cord Will Bind To The Point That It WillTip The Machine. If I...
just for get reverse when you have a problem the first thing i do when i buy a tiller is do away with reverse gear it will make you hurt yourself just go to the end of garden turn around and start over again
5helpful
TB144 pull cord does not catch, pulls free--no start
yes exactly what i would do sounds like the springs are either worn or gummed up or just broken on the dog ears
Top Sears Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a Sears Heavy Machinery Expert? Answer questions, earn points and help others
