Home Logo
A
Anonymous Posted on Apr 27, 2014
How to Set time - Home
UsedClockPartsdotCom
Level 3:
  • Master 277 Answers
  • Posted on Oct 02, 2016
Master
Level 3:
Answers
277
Questions
0
Helped
146977
Points
4537
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
I can set the time on my Kambrook KD86 timer and then two events (light on and off ). Should I press SET after time and each event and then AUTO ?
Question edited to add maker.
Question moved to Timers.
KD86 Instructions:
Set slider to SET TIME and set the time using the HR & MIN buttons.
Set slider to SET PROG,
Use the HR & MIN buttons to set the turn on time and press SET.
Press EVE and set the turn off time, then press SET.
You can use the EVE button to set further ON and OFF times.
When you have set the times you want, set slider to AUTO.
https://www.google.com/search?q=kambrook+timer+kd86+manual
CHANGE TIME SETTINGS ON CALCULATOR DR-210R
  1. Turn on the Calculator: Press the "ON" or "AC" button to turn on the calculator.
  2. Enter Time Set Mode: To access the time settings, you may need to press a specific button or key combination. Look for a button labeled "TIME SET," "TIME," "SET," or similar. Press this button to enter the time set mode.
  3. Set the Date and Time: Once you are in the time set mode, you can use the number keys and other function keys to enter the date and time information. Typically, you'll enter the date as month/day/year (e.g., MM/DD/YYYY) and the time as hours:minutes (e.g., HH:MM). Use the "AM/PM" or "24HR" key to toggle between the 12-hour and 24-hour time formats.
  4. Confirm Settings: After entering the date and time, press the "SET" or "ENTER" button to confirm your settings.
  5. Exit Time Set Mode: Press the "TIME SET," "TIME," "SET," or another designated button to exit the time set mode and return to regular calculator mode.
How do you set the time on a Homedics SS-5075 alarm clock?
https://www.helpowl.com/q/HoMedics/SS5075/Technical-Support/set-time-time-set-button-hourminute/1033266
Press and hold the TIME SET button (for more than 3 seconds) and press "+" and "-" to "INCREASE" (+) and "DECREASE" (-) to the hour. Press the TIME SET button again to set the minutes and use the "+" and "-" to "INCREASE" (+) and "DECREASE" (-) the minutes. Press the TIME SET button again to set the Year, Month and Day
Mar 13, 2019 • Home
How do i set the time on my kindle fire?
Tap the little gear icon in the upper-right, tap "More...", then tap "Date & Time".
If you want the Kindle to automatically set the correct date and time from the internet, make sure "Automatic" is set ON, tap "Select Time Zone" then set your time zone. Otherwise set "Automatic" to Off" then tap "Set Time", set the time, then tap "Set Date" and set the date.
May 02, 2014 • GPS
1helpful
3answers
Can not change time zone on sharper image model lm521 projection clock
I got to liking the Sharper Image LM521 Digital Clock so much that I finally took the time to figure out how to manually set it-it was that or toss it! The instructions are as follows:
NOTE!!!
AFTER installing fresh batteries, or removing and reinstalling the batteries:
Successively pressing the "SET" button results in steps 1.) to 11.) below, each of which describes the particular/specific LM521 clock function you you can manually set.
HOWEVER, pressing the "SET" button after the clock had been previous set and running, will start the manual clock settings from step "2.)," "SET Offset Hours..." To start from step 1.), remove and reinstall the batteries.
PROGRAM/MANUAL SETTING MODE
After inserting the batteries:
The whole LCD screen lights up showing the different settings, etc.
After several seconds, the LCD screen clears and displays:
A flashing antenna
Upper left hand side of the LCD display. USA Time Zone Map
Middle right side of the LCD display (if necessary, to see, remove and reinsert batteries).
WAIT FOR AUTO TIME SET
A flashing antenna
> This indicates the clock is trying to auto set the time according to the WWVB radio/satellite time signal. Set on windowsill for best chance of success.
If it can't detect the signal, mannual setting is required, starting with the time zone.
> Manually set time ONLY if you are absolutely certain the WWVB signal cannot be found. Otherwise any manual time setting will be auto set to the WWVB time when its signal is detected, which may be many hours later.
SET USA Time Zone
1.) Press "SET" -- US time zone
> press "MODE" repeatedly until the desired time zone is reached.
5 = Eastern standard time (default setting)
6 = Central standard time
7 = Mountain standard time
8 = Pacific standard time
9 = Alaskan standard time
SET Offset Hours to Compensate for Satellite Signal
2.) After step 1.) above, press "SET"
A flashing "-7h" (minus 7 hours, default) and flashing USA Time Zone map appear.
This default setting worked just fine in New Mexico, MST, and may also work for your time zone as well.
> Press "MODE" to set from "-0" to "-12h" (minus 0 to 12 hours).
> Set to "-0h" if the satellite time signal set your clock to the correct time for the US time zone you live in.
> Set from "-1h" to "-12" to offset the time set by the satellite signal in case it does not match the time in your time zone. (E.g., 3pm -1h = 2pm.)
> NOTE: The default setting is -7h. If the satellite signal resets the time, say to 9pm, the time displayed will be 2pm (9pm-7h)--but if it should display 5pm instead to match your time zone, then set offset to -4h. Hence, the need to correctly set the offset hours if the -7h default value does not work for you.
SET Daylight Savings Time (DST)
3.) Press "SET" -- DST (Daylight Savings Time)
> Press "MODE" to set ON/OFF
SET Time
4.) Press "SET" (5no = seconds)
"5no" displays, plus flashing bars for seconds (not minutes as it falsely seems).
> Press "MODE" to set from 0 to 60 seconds
5.) Press "SET" (set hours)
> hour bars flash > press "MODE" to set hours
6.) Press "SET" (set minutes)
> minute bars flash > press "MODE" to set minutes
SET Date
7.) Press "SET"
> press "MODE" set year
8.) Press "SET"
> press "MODE" set month
9.) Press "SET"
> press "MODE" set day
SET Week Day
10.) Press "SET"
> press "MODE" set week day, Mom through Sun (Mo is default)
SET Standard (12) / Military (24) Time
11.) Press "SET"
> Press "MODE" set 12/24
CEILING DISPLAY:
SET/ROTATE Ceiling Projected Time/Temp Position
12.) Repeatedly press button with four tiny arrows pointing opposite each other (rightside of "DSPL" button) until the Time/Temperature display on the ceiling is oriented how you want it.
SET Ceiling Projection Brightness, or turn off
13.) Pressing button with sun symbol (leftside of "DSPL" button) cycles ceiling display from off, to brightness levels 1, 2, and 3.
SELECT between Ceiling Projected Time, Temp or Both
14.) Pressing "DISPL" repeatedly cycles between M0 (time), M1 (temperature), M2 (time & temperature auto switch every second or so).
1helpful
How do i change the time
Hold the [time] button and hold it, while pressing down on [time] press [set +] or [set -] . [Set +] will move the time forward and [set -] will adjust the time back. If you hold down [set +] or [set -] the time will move faster.
50helpful
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 • Watches
What does set point time and set point temperature mean
set point time time when the set point temp activates
say i want my house to be 70 degrees while i sleep
i'll set the set point time to 11 when i go to bed, and the set point temp at 70
so to do what youwould like set the set point time for midnight and the thempature fore 55 or lowest seting with will keep the heater off. for the second time setting set point time at 5 am and set point tempature at desired temp
20helpful
6answers
Resetting clock
Press the SET button until you cycle through the alarms and the Colons on the time start to flash. use the right and left arrows from the CD buttons to adjust time; After time is set; press the SET button. Be careful to not fat finger and hit the CD button when pressing the SET buttons. That will turn on the AWFUL NAP timer. That's another headache.
. Stop the Nap alarm Press NAP to start NAP flashing. Press and hold NAP to cancel the nap setting. If this does not work; try again. It seems to take me a time or 2 to get it to work.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
