https://fuse-box.info > cadillac > cadillac-cts-2008-2009...
Here you will find fuse box diagrams of Cadillac CTS 2008, 2009, 2010, 2011, 2012, 2013 and 2014, get information about the location of the fuse panels inside ...
You've visited this page 2 times. Last visit: 19/11/22
Hi Ed, I sent you the link to download the user manual of the CTS600 and CTS1200 Crown amplifiers
I hope ter serves to repair your Crown power unit
Greetings Franco Dosil
The dimming fuse supplies battery positive voltage to the license lamps, underhood lamp and to the dash integration module (DIM) park lamp input, for interior lamps dimming.
Dimming fuse 10 amp. under hood fuse box. the park lamp relay supply's battery power to that fuse .
OK, look for the 20 amp fuse that says "I/P OUTLET" and the relay that says CIGAR RELAY in this picture (relay is below the highlighted "HDLP WASH RELAY MINI--OPT"// the fuse is to the right of the highlighted relay.
check to see if your brake lights work if not then check fuses first and if fuses are good then change brake switch. if the light do work you will need to change the solenoid in the shifter housing.
