The drainage tube from self defrost freezes up and ice builds up inside the freezer.I have had to take the 2 lower shelves out and remove the back panel covering the fins and use a hairdryer to heat up the small opening for quite a while until it thaws. Have had to do it 2 times a year. What is the solution to this design flaw?
SOURCE: water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
SOURCE: The freezer is not freezing evenly.
Yes, the fan needs to be running. I can't say for sure since I can't test it, but if you can, test for voltage to the fan wires. If it has voltage, replace the fan.
SOURCE: Only upper section of the freezer works, heavy ice-buildup.
Good day,
You are right about the assumption it's a refrigerant leak. Simply recharging it is a waste since it would shortly if not sooner leak back out.
There are a lot of areas that can be the origin of the leak and unfortunately some models actually run lines inside the walls where they cannot be accessed.
As well if it's due to corroding tubing then it's somewhat like fixing a rotten tire.
The only hope would be a tech familiar with your make and model who is aware of a specific area that is prone to leakage in an isolated area that is not prone to travel.
You may choose to try calling around, but the chances are slim.
Testimonial: "Thank you for your prompt response, although I was hoping for better news. Too bad, the freezer is otherwise in perfect condition."
