SOURCE: Paper Thickness Lever
i think there's a problem with the pin of your print head. it becoming worn-out. so replace it, or you buy the head print new one...
SOURCE: The paper just feeds through my Epson 1400 without
what? you expect me to give you an answer to my own problem for nothing while you want to charge me $20 for "maybe" some help to resolve my printer issue? You've got to be kidding! What a "chintzy" way to make a buck!
SOURCE: Can I use thick paper to print on Epson DX 8400?
There is a Paper Thickness lever on the left hand side of the front of the printer. If you go to the following website:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=Doc&oid=58606&prodoid=56291067
You can get the Product Information Guide, or the User's Guide. Both of these will describe which setting you should use for a wide variety of paper. For normal single sheets of paper the lever should be in the down or "L" position. If you are using envelopes the guide instructs that the lever should be in the up or "H" position. They give you a complete table with the appropriate settings to use depending on the thickness.
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
