Make sure that your brew unit is clean and lubricated. The CPU on the machine uses the brew unit to calculate the amount of coffee it grinds. If the brew unit is dirty and hard to turn strange things will happen.
Service Center information.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
SOURCE: My new accademia gaggia won't work, error code 05
see this causes and fix it. God bless you
Reset the code read your instr. manual
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord, the internal fuse or the thermostat and heating elements replace as needed.
SOURCE: My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
