timing marks on crank gear mark with white chalk so you can see with a timing light dont belive tensioner is adjustable Chiltons Repair book for head gasket. out of water? where?
the look up info is marked 3.0 L, v6, S , FI, im taking , the S = it's a single if you open the hood and look at top of motor there should be a logo in middle of motor.
A bad flasher would not usually cause no brake light, the problem you are discribing sounds like it could be a bad multi function switch, that is the turn signal/hazard switch, everything you have that is not wrking, goes through that switch on most cars. Would need to look and a schematic to make sure and do some voltage checks, but that is the direction I would trouble shoot it in.
