I've checked all the connections, and I'm at a loss. Help?
SOURCE: I need an AC/DC 19v
Hi Curtis
This a hard to find item... if you are quick, you can get one here or here
Only other place I could find one to do the job for you... was rated at 1 amp, and cost $213.00 !!
Thanks for using FixYa, If you consider the advice I have given you
as sound, a FixYa rating is a great reward for my efforts to help
you. Cheers.
regards
robotek
SOURCE: RCA Wireless Speakers WSP 155
Hi, the following alternative may solve your problem:
Check to make sure the volume on the audio source is set to a normal volume.If the volume is too low, the transmitter will not turn on.
If it does not solve it, your system has a power problem in the power supply. Make checks on the regulator, it might have a open, if you are not a tech, let a tech take a look on your set to verify the damage component.
SOURCE: my protection light flashes from
check how good your earth connection is, you may need to scrape of some paint beneath it to get a good connection, kicker amps draw a lot of power so good cable connections are a must. If the earth connection is clean, maybe try thicker cable to allow higher current.
