Need location of the circuit board to replace fuse
SOURCE: I have LSC26905TT LG refrigerator. I found out
the following link might help: http://www.mcmelectronics.com/browse/LG/1000318
Testimonial: "Great information. Thanks."
SOURCE: I need a replacement water line for my LG
If the water is leaking from the freezer door hinge the door would have to be replaced as the waterline in the door is foamed in place.
If the leak is from the back where the plastic lines are they are replaceable.
Contact LG @ 1 800 243-0000 and give the exact location of the bad waterline since there a couple on the unit.
SOURCE: burned our fuse in circuit board
it is a 250V 15 amp. clip the fuse off the wire, close, and solider in a new one. Terrible design. LG should have to replace free or be sued !
SOURCE: Just need to replace that 15 amp fuse on the
most fuses on the board are only replaced with the board . I would use a after market fuse of the same rating . and if it blower it again find out why ... l g may not supply the fuse but any electronic supply should have it . mm
Testimonial: "Good information. I'm going to install a fuse holder as I replace it. "
