Whirlpool LER5636P Electric Dryer Logo
Posted on Jun 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer wont start when start button is pressed, but humming sound
I have a whirlpool, heavy duty super capacity
5 cycle
3 temperature electric dryer
model # LER5636EQ1
put a load of clothes in the dryer and pressed the start button. Nothing happend but the humming sound.
The drum inside does not turn.
checked the breaker, its fine
dray8165
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jul 20, 2009
dray8165
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
7633
Points
46
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Jun 21, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
822
Points
My whirlpool dryer model # GEQ8858KQ0 will not start when the start button is pressed. If left on timed dry you can hear the timer kick in and try to start but it will not.
  • 1 more comment
  • Virgil Watts Jun 15, 2014
    Sounds like somthing not letting the drum or the motor turn.
Anonymous
Level 3:
  • Master 999 Answers
  • Posted on Jun 20, 2009
Anonymous
Master
Level 3:
Answers
999
Questions
Helped
310998
Points
2740
Try rotating by hand a little. If it starts after that it could be a bad armature and the motor is shot. If it is very difficult to rotate check for something in the blower wheel.
Eric
I have a Whirlpool Imperial 8 cycle, 5 temp Ultimate Care Heavy Duty Super Capacity Plus electric dryer that won't get hot to dry my clothes.
Can only be a few things
high temp fuse
high limit thermostat
failed element.
VIDEO
https://www.youtube.com/watch?v=fv2UqRUKnm0
Parts
Official Whirlpool Dryer Parts ' Order Today, Ships ... - PartSelect
www.partselect.com > Whirlpool-Dryer-Parts
The Dryer Thermal Fuse (Thermal Cutoff, Temperature Fuse) is a 2 by ½ inch, white, plastic safety mechanism that stops the flow of electricity to the motor circuit ...
Whirlpool - Dryer Parts - Appliance Parts - The Home Depot
www.homedepot.com > ... > Dryer Parts
Results 1 - 24 of 29 - Get free shipping on qualified Whirlpool Dryer Parts or Buy Online Pick Up in Store today ... WhirlpoolTop Load Washer/Dryer Cover in Gray.
Replacement Parts ' Whirlpool
www.whirlpool.ca > en_ca > services > replacement-parts
Our factory certified parts provide you with a promise only Whirlpool brand can make, that through our safe and genuine quality replacement parts, we will care ...
Dryer sometimes works and sometimes doesn't, what's the problem?
i have a feeling that it's a fault in the power chord, take it out and double check. it would make sense if it only work now and then after you have plugged it back in because it could have made the wires touch again to make it work
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
I have a Whirlpool Duet Dryer that is locked on the heavy duty cycle, I cant switch to another setting, it wont cancel out. I've tried unplugging it for some time to reset it. It is still stuck o
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be replaced.next time send the model number off of the machine
2helpful
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Admiral heavy duty super capacity 5 cycle3 temperature won't start
dryer will not start when start button id pushed
Admiral heavy duty super capacity 5 cycle 3 temperature only heats some time
susara awz 7457 ne greje koji sum moguci kvarovi jel moye iko da mi pomogne..unapred hvala
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shield™ Plus Feature is preset to on during the permanent press cycle.
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
