Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault. See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm If everything above is OK then the thermostat or the auto sensor is not working correctly.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault. See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Watch the burner assembly, shortly after starting the
dryer the ignitor should begin to glow. If it glows for several
seconds (up to 15 seconds) and then goes out, then the problem
is probably the solenoids (coils). If the ignitor glows and stays
on, then the problem is usually the flame sensor.
Gas dryer?
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault. Electric dryer?Temperature sensor has failed or heating element has burned out.
