I have two 10 inch type R subwoofers being powered by a alpine mrp-m500 amp. I put them in a 2005 saturn ion with the advanced audio system (AAS). I used the high pass converter to rca and my subs cut out when i turn the volume up past three notches. I have turned the gain and eq all the way down on the amp and my head unit and it still cuts out at the sme time. I purchased the subs as a loaded setup so i do not know what the ohm rating is or any ohr specs on the subs. Please help thank you.
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
They sound good till i hit that same point in the volume every time. No matter the settings.
See that is what i was thinking. I actually don't have a capacitor on it. I have a one farad siting i my garage. I may have to put it on there and see f it fixs it.
No the cap did not help anything. I am at a loss. Is it possable the amp is too small for these subs. What are the specs on the type r 10's?
HELP!
