I cant seem to figure out how to remove the battery for easy transportation.
SOURCE: charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
SOURCE: I have a Go Go
you need to use an electric screwdriver or regular one with long narrow blade, then turn the batter housing over and insert the driver into the holes on the bottom of the case. Use slow speed in the counterclockwise direction, you will feel the screws release as there will be a clicking sound. Seperate the case and disconnect the batteries. Charge them on a car battery charger, put the batteries in parallel by using jumper cables then hook chargers to the batteries. Sometimes the scooter charger will not fully charge. Use 6amp or lower setting while charging. Also check and see if the fuse is blown or not inserted all the way.
