1998 Dodge Caravan Logo
Posted on Jun 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After sitting in driveway, back wheels have completely locked up.
The (front) cv-joint broke in half (while driving down the road) May 2008. Van sat in driveway approx. 1 yr. We just replaced the cv joint, but now the van wont move because the back wheels have locked up. We've spent too much time, and tried many things--no go! They seem to be solidly locked in place.?...?
  • Anonymous Mar 29, 2014
    van broke down and sat on road for 2 months
Anonymous
Level 2:
  • Expert 175 Answers
  • Posted on Jun 20, 2009
Anonymous
Expert
Level 2:
Answers
175
Questions
0
Helped
67355
Points
502
Chock the front tires, loosen up the lug nutes on the rear tires, jack the rear end up, uncap the adjuster dust caps on the back of the rear drums, either use a brake spoon or straight blade screwdriver and turn the star adjuster while spinning the wheel until you have no resistance. If this does not work remove the rear tires and hit the sides of the drums with a small sledge hammer or hammer to loosen & break up the rust, When you get movement on the drum, hit it betweeen the studs. Be patient, this may take some time.
2answers
How do I decide if it's the drive shaft or the CV joint?
It is easier to change the whole half shaft than it is to change just the CV joint.
2004 Buick Rainier four wheel is stuck in AWD drive all the time .
All wheel drive is just that-- All wheel drive-- not to be confused with 4 wheel drive . The difference is with AWD there is a 3rd diff in the transmission that allows the front and rear wheels to operate at different road speeds . When 4wd is selected that 3rd diff is locked and so both front and rear wheels drive at the same speed regardless of ups and downs in the road surface . This results in a torque wind up in the drive train and places load on "U" joints --splines --CV joints and gear teeth . The grinding on turning corners will be the CV joints trying not to flex because of the torque wind up . How to prevent this problem=== Do not use 4wd on hard road surfaces === as the tyres cannot slip to relieve the torque Restrict the 4wd use to snow , mud and loose surfaces TO fix the problem unselect 4wd drive and reverse several yards to release the pressure in the drive train and the actuator has a chance to pull the gear out of lock up. If that doesn't work check that the actuator is actually working
How dificult is it to change drive shaft universal joints myself on my ford focus 1998 5 door hatch
You have front wheel drive & CV Joints,
not U-Joints ,is that not correct
CV Drive Axles in front wheel drive vehicles
are just replaced as a complete axle assy
I have a 2000 Chrysler Concorde. Good Car. 145000 miles. Changes the struts last year and this year changes the bushings in the front wheel drive. The car is making a popping noise in the front end and...
could be cv joint but jack up wheels and move tire up down and left right up down if play check ball joints /anti-sway bar bushings--------if play left to right than check idler arms and steering system /and anti sway bar bushings
3helpful
CV joint questions
well now,,,il tell you a storie,,,better sit down?
the cv joints are the joints in a drive train that for use of a better word "bend the drive shaft" so it dont brake when you turn a corner,,,ie:parking! inside the cv joint is held on the drive shaft be some splines in the drive shaft and a spring clip holds it all together there is an "inner bell" it has normaly 5 slots in it that have big "ball bearings" in them that slid around up and down these slots on the out side of the cv joint is the outer "bell" this also has slots that the ball bearings fit into so the drive trough the cv is compleat,,,when you turn the wheels the cv joints slids round on these ball bearings twisting round but the drive from the engine is still transmited to the road wheeles trough the cv
when this cv joint starts to were out the ball bearings are pitted and not ball shaped any more and the slots they run in are not smooth that to gets pitted what happens is the cv starts to "crack" under load,,,and vibrate when turning or being driven you drive down the road at 50 mph and the car feels like its driving over stones in the road its vidrating off the cv joint then when you turn the wheel on full lock to pull away you here a very big cracking or clicking sound, like,,,,,click click click, and the more power you put on the more they click very soon people start turning around and look at you? oh yes they here it to!
the vibration that comes off the cv will reck the transmission becouse of the wipping of the drive shafts,,,, to test your cv joints to see if there good or bad one's put the car on full lock and pull away,, if there is a cracking sound or a klicking sound there shot away and you need new ones fitted
now then,,,storie over,,, its time for sleepy sleeps
I am not sure if the wheel bearing on the front end is broke. it makes a loud poping noise when turning and the wheel is towed in
Loud popping/grinding most noticeably heard when turning is normally a sign of a bad CV joint. Look under the van where the axle half-shafts come out of the transaxle and connect to the backside of the wheel assembly. Are the rubber boots on the axles torn or missing?
If you hear the popping only in left turns, your right CV joint is bad, If you hear the popping only in right turns, your left CV joint is bad.
2answers
Inner cv joints
inner cv joints are the joints on the inner half of the axle shaftswhere they go into the transmission. sometimes the easiest thing to do is replace the axle shafts
2answers
Tranny in a 98 caravan
sounds like your front bearing are locked up.  This happened to me once in a van that had been sitting awhile.
2answers
I broke the front wheel drive on my 84 corolla.
sounds like you might have a broke axel or cv joint
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
