Model fafw3801lw2
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
SOURCE: how to replace the selector control knob on a
Push-in center knob and and turn Counter Clockwise to loose it from the treaded shaft. Next, without Pushing in, continue turning CC till it comes off.
If necessary, remove the outer indicator knob by sqeezing the two release clips in the center. This knob is keyed to only go back on one way so you don't need to remember its location before removal.
Reverse the process to install new knobs.
Oh, if you need to replace the cam or timer which are behind these knobs, the front panel will have to be removed by first removing the top cover of the washer. Now you can access the six screws inside the washer and one in front behind the detergent dispenser.
SOURCE: error code E70 on my Frigidaire front loading
The hot and cold water hoses were connected wrong to the washer.
SOURCE: Just want to know how to reset a Frigidaire Front
My 8 hour delay won't go off. Not sure how to get it to and the manual doesn't help at all. Can anyone advise? thanks.
