Panasonic KX-T7633 Corded Phone Logo
A
Anonymous Posted on Apr 26, 2014
How can we turn off the "New Voice Mail" indicator and blinking light? We have called up our voicemail and do NOT have any voicemails (and thus can't clear anything).
5 Related Answers
Anonymous
  • 108 Answers
  • Posted on Aug 05, 2008
SOURCE: Transfer call directly to voicemail
Since you did not mension the phone system type I am assuming it is a Digital like the KX-TD500. You can transfer direct to voicemail if you have a VT ( Voicemail Transfer ) button on your phone. When you want to transfer the party you are talking to, press VT and dial the extension/mailbox number you wish to transfer the call to and hang up to complete the transfer. If you do not have a VT key you can program one of your flexable buttons as a VT key by pressing your PROGRAM button, dial 9 9, press the button to be programmed, dial 8 and the voicemail extension number, press AUTO DIAL/STORE and then press PROGRAM to exit station programming. Good Luck. ....Mike
Dan Wolfson
  • 3 Answers
  • Posted on Nov 25, 2008
SOURCE: Panasonic KC-TC1713 cordless phone - Voicemail light stays on
You guys had the owner manual scanned on your web site so I just RTFM ;~).
To clear the voicemail light on the base unit, first press the Redial button on the phone, then hold down the Clear button on the phone for a few seconds. The light should go out.
Here's a tip: I wrote down the above instructions on a small piece of paper and taped them to the back of the phone. You could also tape the note on the inside the battery door.
Anonymous
  • Posted on Jan 10, 2009
SOURCE: access voicemail from another line while away from home
The previous solution only works for older machines. I have the same Panasonic model and this works every time.
On your handset, hit the top center button(menu). Touch the arrow down button 7 times. Should say "Initial settings". Hit top right button on handset (display shows this is now the "select" key). Display now shows "Set Answering". Hit top right button again ( select key). Display now reads "Ring Count". Hit arrow down button 2 times. Display now reads "Remote Code". Hit select key again and enter your desired 2 digit remote code. Hit "Off" key. When you call the answering machine from the road, simply enter those same digits. Piece of cake. Enjoy.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Sep 18, 2009
SOURCE: Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Anonymous
  • Posted on Jun 23, 2010
SOURCE: can not get rid of New voicemail message
Press and hold the off button until the handset beeps
I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
Question edited for clarity.
This phone system has two features.
Answerphone system which records messages to the unit.
and
Voice Mail System which is an extended (often paid) service from your telephone provider.
Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.
Page 32 refers
https://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdf
Retrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply.
Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically.
Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33
Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone.
Voicemail light does not come on even though I have messages. Phone is a RadioShack 43-325 cordless phone. Hope someone can help.
If there are new voicemail messages, likely you will hear "stutter tone" followed by dial tone when you raise or use the handset. If you don't hear stutter tone, then likely messages in your provider voice mail service have been marked read and therefor no new voicemail indicator.
If you cleared voice mail indication on your RS 43-325 phone, voicemail indicators will remain off until the next new voice mail message is recieved.
See page 13 of manual for further information.
https://manualzz.com/doc/937306/radio-shack-43-325-user-s-guide
2answers
How do I clear phone of a new voice mail message?
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Blinking New Voice Mail light
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
3helpful
Voice mail blinks & won't clear
There are messages on the voicemail system provided by your telephone company. This records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
8helpful
2answers
Voicemail light flashing but no message
This can usually be fixed by calling the phone number that the voice mail indicator light is flashing on from a different phone number. Leave a voice mail message and then go into the voice mail and delete the message that you just left. The indicator light should then go out.
Message indicator light flashing
Voice mail light blinks, but ther is no message the mail box
You're subscribed to a voicemail system provided by your telephone company that takes messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
3helpful
2answers
New Voice Mail flashing light
What worked for me was to call my phone from another phone and leave myself a voicemail. I then went in and retrieved and deleted that voicemail. Once I hung up from my voicemail service my handsets reset about 10 seconds later.
I hope this helps!
35helpful
7answers
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
