When throttle is turned you can hear a clicking sound from battery compartment. What can I do to fix? Thanks
Plz.we have to use a little common scense in this case.The razor-dirt rocket 500/or any model that run on _Electricity can not get "wet" for any reason.For example what happens when you drive a remote control car in water? The electrical motor dies,not before smoking first. It is nyeve of the manufacture to not a protective cover on or around the motor, which electricity flows inside. the 3 vent holes is for heat ventilation
I had the same problem i put a heater on the motor and it must have dried something and it worked
The motor must be getting wet i had power to the motor but the motor would not come on to i put the heater on oit
MAKE SURE BATTERY IS OK. REMOVE BATT
CONNECTIONS AND THOROUGHLY CLEAN
BATT POSTS AND CONNECTIONS WHERE
THEY FIT ON POSTS, RECONNECT AND TRY.
IF STILL NO CRANKING, MAYBE BATT IS GONE.
