We've plugged it into different outlets and still no power. We've only used it once about a week ago and it was working fine. Now we can't even turn it on. Any suggestions? Thanks for your help!
SOURCE: How do I replace the drive belt on a mastercraft
It's going to be under that black plastic cover, if yours is a model like the one pictured here.
You'll need to find a replacement belt to begin with, Then remove the screws that hold the cover on. Usually the belt on these is a toothed belt, and you may need to remove one of the pulleys to get the belt to slide on. Just break the retaining nut loose and the pulley should slide out and off. Make sure you keep track of where washers and shims go when you replace it.
I couldn't find a new belt for it. Good luck with that, to begin with.. Maybe if you try here they can point you in the right direction.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
