I figure it's probably just a channel mishap but I can't seem to figure it out. We have DirectTV.
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
SOURCE: I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
SOURCE: sanyo dvd/vcr combo
Your universal remote would have seperate selection buttons for VCR and DVD. If you don't have a VCR button, use AUX. Try programming each function seperately - DVD code for your manufactirer on the DVD button and VCR code for your manufacturer on the VCR button.
SOURCE: I need to get one manual or download for free,
Please download manual from:
http://www.instructionsmanuals.com/u2/pdf/reproductor_dvd/Sanyo-DVW7000-en.pdf
Testimonial: "Thanks, checked it is downloading, but already got it from other site and downloaded yesterday after emailing to you. can i guy remote from you."
SOURCE: I have lost the remote
You may not be able to buy a replacement original remote for it, but a universal remote may work - it is then a matter of code (if needed) to operate most of the basic functions of your combo. You could always look on eBay amazon, or ask your local store about the universal remote. Logitech are the best universal remotes on the market - these range from basic types to all-in-one, with the price of each varying. You should be able to buy something like that locally (similar brand to Logitech which will serve the same purpose) - if Sanyo won't put an order for the original remote in for you.
