Hello my sony bravia has sync with wD Live hub and i can't use my scene selet on the sony remote
I'm assuming this is the Bravia "Scene" button that activates your custom sound and video settings, like cinema and sports and such.
Does the rest of your remote work? It's possible that the one button on your remote doesn't work. See my other post here (Cannot control receiver from remote) to check if your remote is working by seeing if the LED's on the end light up. Try buttons which do work, like volume, channel, menu, whatever and look for the LED lighting up. Then press the Scene button and see if the LED lights up. If it doesn't and you've tried pressing firmly, then likely the button is dead and it's time for a new remote. It's very rare, but it can happen. Talk to your sales centre or manufacturer for assistance.
If it does light up, and other functions on the remote work - then it's possible you can only use the Scene feature on the remote when the TV is in a different "state". For example, you might not be able to use it while watching a movie or show, but you may have to enter a menu first. This sounds silly - why have a button that only works some of the time? Because sometimes engineers (or the guy who develops the TV software) are forced to make things in a less than ideal way, for one reason or another. Now, as to what menu you might have to enter - try the general Menu, then try Settings, and look for something like "picture", "setup", "scene". After each on-screen menu change (if the image on the screen changes), try the "Scene" button again.
038
533
679
505
533 038 039 064 102 130 505
Ok.
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
