Check the links to talk to a technician or service. I find no easy access to matching a sheet of error codes with your carrier VRF on the web. I encounter codes but the sheets fail to identify the models! Those codes refer to a decrease malfunction which defies interpretation by any but an air conditioning technician. So, the most direct route to your query answer is at the above link.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need anything else air conditioning related don't be afraid to check us out our AC Repair and information online
Error code should have a description of Of a part or sensor next to the wiring diagram behind a panel on the unit what is it doing or not doing clean the coils change the filters check line and transformer voltage
description: cooling fail action is activated. Action: check compressor operation. turn off main power-restart the unit. see more: Air Conditioning Fault Codes
