HP Compaq nc6320 Notebook Logo
a
adel Posted on Apr 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove bios password hp compaq nx9030 device
Archie Cruz
Level 3:
  • Master 641 Answers
  • Posted on Apr 26, 2014
Archie Cruz
Master
Level 3:
Answers
641
Questions
0
Helped
163528
Points
1736
Hi Adel,
I am afraid there is no way still to retrieve BIOS password but you may want to contact HP Support to check if they have ways to check that for you. Usually for the case you have it is replace MOBO already. Please check the number on the link below base on your location.
Contact HP Phone Assist HP Official Site
5 Related Answers
sparkyuiop
Phillip Thorne
  • 91 Answers
  • Posted on Dec 03, 2008
SOURCE: HP Compaq nc6320 PC bios password
Ok, as long as the high security level has not been set in the bios then the following will work to reset / disable the bios password.
1. Remove the battery and mains adapter.
2. Remove the memory cover on the back of the laptop and remove the 2 keyboard screws.
3. Open the laptop and at the top of the keyboard you will see 4 sliding tabs. They are located between the 'Esc & F1 keys' 'F4 & F5 keys' 'F8 & F9 keys' and 'F12 & delete keys'. Slide these down and lift the keyboard up and pull forward slightly so as to disengauge the bottom lugs. Be carefull as there is a ribbon cable at the bottom that does not need to be tugged or removed.
4. You will now see at the bottom behind the keyboard a small battery connected to the motherboard. Gently pull the small white plug upwards untill it is removed from the board.
5. Wait 5 minutes and re-connect the small battery plug.
6. Re-install the keyboard and push back the clips. You do not need to replace the screws yet.
7. Apply the DC jack and power on - DO NOT INSTALL THE MAIN BATTERY.
8. Turn the laptop on while pressing f10 repeatedly but slowly - Do not hold it.
9. If high security is disabled you should now be in the setup screen, select 'Restore Defaults' and press F10 to save.
10. The password is now removed.
If this does not work then HP say that there is no other way to reset it. Im not sure about that, there probably is by some method of de-soldering the bios chip. However the above method worked for me so I hope it does for you. Please rate if you have any luck.
Sparkyuiop.
Anonymous
  • 66 Answers
  • Posted on Feb 18, 2009
SOURCE: I Forget the BIOS setup password
When you start your computer, tap F2 key to enter the BIOS setup. In the security menu is the area for removing/resetting BIOS password.
chamboard
B.Th. Pluijm
  • 558 Answers
  • Posted on Dec 13, 2009
SOURCE: removing bios password on Compaq NX6120
http://www.tech-faq.com/reset-bios-password.shtml see on this site or you can also google for it
Anonymous
  • 2653 Answers
  • Posted on Apr 04, 2010
SOURCE: how can i remove bios password fro hp 6735s
You won't be able to do it yourself. You'll have to contact an authorized HP support center.
There used to be "easy" ways but now the password is stored on a chip on the motherboard.
Anonymous
  • Posted on Apr 16, 2010
SOURCE: how can i reset CMOS/BIOS password for HP compaq tc4400 laptop
how can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
Forgot password Hp nx9030
Windows access? Bios? hard drive? Which???
1helpful
My hp nx9030 keep rebooting itself with the message, PXE E61 media test failure check cable, PXE -MOF EXITING PXE ROM.what can i do
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
HP Compaq nx9030 bios dead how to replace bios with bootable stick
Download the bios version and the instructions from HP support site...and Im not sure it will work from boot-able stick ..cause from what i know only for asus motherboards it let you flash the bios ..but for all others you have to make a boot-able floppy disk ..and reinstall bios..
http://www8.hp.com/us/en/hp-search/search-results.html?charset=iso-8859-1&lk=1&la=en&nh=10&st=1&rf=0&qp=&qs=&qt=install+bios+for+notebook&h_audience=&tridion=0&hps=Home&hpr=http%3A//h41131.www4.hp.com/us/en&h_audiencerestrict=&hpvc=sitewide&hph=&hpo=&hpn=Home&hpl=1&hpa=http%3A//www.hp.com/country/us/en/contact_us.html&
uf=1&regionStatus=ACTIVE&cc=us&lang=en
It seams that you can install from windows after all ..but if you do not have a working system on the notebook it still needs to be installed from an diskette ..
2helpful
How to remove my hard disk from HP Compaq nx9030
you have it explained in this manual from page 93 to page 97. It's very easy, but be careful when you remove the hard drive conector, if fits very hard to the HD...excuse my english.
I lost my sound device in my laptop
I hope you didnt lost that device physically :)
If something is wrong with your sound drivers then you can download latest drivers from HP support site
1helpful
Power On password has been enabled on the notebook
The power on password is configured from the BIOS and removing the BIOS battery will not reset the BIOS and remove the password as it is stored on an EEPROM chip.
This password is to protect unauthorized access to data on the laptop and the hard drive. There are no backdoor passwords available.
Ask the person who set the password, then you will be able to remove it by going into the BIOS setup.
HP Compaq nx9030 power problems
all i do is hit Fn butten when booting
2answers
Forgot BIOS password.
1.) Unplug AC, take out the main battery.
2.) Take out /disconnect the RTC (real time clock) battery for app. half an hour (the period of 5 min as specified in the MSG normally is not long enough).
3.) Plug in the AC adapter (batteries still removed); computer should boot automatically, if not use the power button.
4.) The machine will boot and show the 162-error-msg "system options not set". Use F1 to save the settings.
5.) Shut down the computer and disconnect AC power again.
6.) Re-connect the RTC-battery.
7.) Install the battery pack(s).
8.) Restart the computer.
Caveat: All settings are set back to factory standard.
You'll have to enter a correct date/time and change the settings to your needs.
Note: pls strictly keep to the sequence.
Re-starting with the main battery and or RTC-battery inserted will spoil the job.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
