Tomy Thomas The Tank and Friends Track Logo
A
Anonymous Posted on Apr 26, 2014
How to make it smoke? - Tomy Thomas The Tank and Friends Track
3helpful
2009 Kiak 2700 diesel. White smoke. Had injectors reconditioned. Why is it still smoking?
White smoke is more likely coolant. So a head gasket leak or cracked head or cylinder sleeve.
Check coolant level ievel s not dropping.
Can I Smoke a spiral sliced Hickory Smoked Ham?
Hello, Chaz -
From the name "Hickory Smoked Ham", the ham has already been smoked.
To smoke a ham:
1. You need an uncooked, unsmoked (a.k.a. "fresh")
2 The ham needs to be cured. You can read about how to do that here:
https://melissaknorris.com/howtosaltcureham/
3. After curing, the ham can be smoked.
I assume you know the steps to follow to smoke a cured ham.
Best wishes.
Dec 23, 2017 • Grilling
Hi I got a Toyota corolla 160i gle and it was parked very long so wen i started it wen ideling no smoke BT wen hit da fuel it smokes and on take off BT wen driving it does nt smoke
Generally, it may smoke on startup for a few seconds then quit and seem to run fine, then you hit the gas and it smokes again, so Is it white smoke gray smoke or blue smoke? Because IMO it's either a bad head gasket, bad valve guides, rings are going bad ot dumping to much fuel into carb or injectors.
I replace a ignitor on my stove to a new one but it smoke why
Not Enough Information. If an electrical box smokes obviously that means the electronics are severely damaged. We stock dozens of ignition assemblies and they do not smoke. Are you referring to the grill smoking? An electrical box cannot smoke unless it is fried or is on fire. If the stove is smoking you need to clean it and/or burn it off. smoke is caused by grease.
Nov 07, 2013 • Grilling
Smoke engines
Smokes can be of three colors.
1. White smoke.
Excessive white smoke reveals presence of water in fuel, thermostat valve stuck open, or burnt cylinder head gasket.
2. Black smoke.
Black smoke could be observed due to the unburnt fuel or higher percentage of Hydrocarbons during the combustion process, defective regulating valve, ruptured PCV valve, low fuel pump pressure, defective charcoal canister, ruptured or leaking fuel injectors.
3. Blue smoke.
Blue smoke reveals the engine failure.
1helpful
Car wouldn't start, but when it did it was smoking
One thing used many mechanics for diagnosis is: What color was the smoke?
White smoke usually means the engine is failing, and can indicate a leaking head gasklet, a cracked block, or a cracked head. This color smoke is from water and/or coolant getting into the cylinders.
Black smoke indicated too much fuel, and the engine may be "flooded", indicating a less expensidve fix.
Grey smoke indicates oil smoke from worn rings or worn valve stem seals.
The white smoke says you should have someone look at this really quickly to see if immediate attention is needed.
Be blessed
1helpful
I put no-smoke in my crankcase to help with occasional exhaust smoke. When I cranked it after adding it smoked white smoke really bad. Can this be normal?
Unfortunately, with using that product, yes, it is normal... That stuff is not good for any vehicle... What kind of car do you have? Has it had problems with smoking? Black or white smoke? Does the smoke have an odor?
1helpful
2answers
My 1994 Ford Thunderbird now smokes when I start it - no noises in the engine, but smokes like crazy. Check engine light is one now?
state what color the smoke is. White smoke is antifreeze. Gray smoke is fuel, and black smoke is oil. Also have the computer scanned so you know why the light is on.
2answers
Smoke
why kind of smoke is it? sweet smelling smoke? bluish gray smoke? rotten egg smoke?
Top Tomy Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Tomy Toy Expert? Answer questions, earn points and help others
