Pride Celebrity X 3-Wheel Electric Scooter  Logo
A
Anonymous Posted on Apr 25, 2014
Why wont my celebrity x3 charge
Lights, power, charger all working
Stuart Nimmo
Level 2:
Habit-Forming:
New Friend:
  • Expert 88 Answers
  • Posted on Jun 02, 2016
Stuart Nimmo
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
88
Questions
Helped
20891
Points
101
Try the Charging circuit fuses hidden under the mat and floor hatch.
Is the charger OK?
Are the batteries coming to the end of their life?
2 Related Answers
Lee Glascock
  • 384 Answers
  • Posted on May 24, 2009
SOURCE: dead and wont move cant charge but batties are ok
sounds like a dead battery on the unit. see if you can get it replace .
Anonymous
  • Posted on Mar 17, 2013
SOURCE: my victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Scooter wont go
It could be a battery connection, or maybe your key switch?
Or a connection problem between batteries and the motor controller
or the free wheel switch is on.
Wont charge the batterys
hi, is this a built in charger ?
where you insert a mains plug ?
Regards
Manuel for a nextar x3-11
Could be damaged connection where power for charger goes in or even a bad battery
Battery wont charge
could be to hold not holding charge anymore.
Celebrity x scooter wont charge
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Save as a PDF File + Print for future,hope this has helped,Colin.
My nokia x3 wont charge properly. i got the battery changed twice and also got a new charger, but still it wont charge completely. as in, till its connected to the charger it will work, but when it is...
Good day. if you have tools with you, check first the charging pin at the side of the phone unit, sometimes its the PIN inside not in proper position, or check the terminal IC of the charger. But if you cant handle this problem by yourself, i might suggest you must go to your nearest cellphone personnel at your area, coz its too complicated and it required a proper tools. thanks
I have brand new just fitted MK Gel batteries and a known working charger. When the charger is plugged in and charging a orange light should come on or green when fully charged. At the moment only the red...
David, If you are not getting the yellow light on the charger then you have a problem with the charger. What voltage are you getting at the batteries when charging? You can check the charger by removing the end plate where the lights are to see if there is a fuse on the output side of the charger. if there is check to see if the fuse is blown. There probably is a fuse on the other end but since the red light comes on it is good. If you plug the charger into the charger port and put your ear to it you should hear a hum coming from the charger. Hope this helps you
11helpful
2answers
My nokia x3 buttons have stopped working apart from the power button can you help me resolve this please
my nokia x3 buttons have stopped working apart from the power button can you help me resolve this please. The beep sound is present while navigating the keys.
2answers
Dead and wont move cant charge but batties are ok
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
