I'm trying to calibrate pen but it beeps on circles on all four corners but won't work on middle dot so it doesn't recalibrate.
SOURCE: Leapster pen not working
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Call up Leapster (c/s I reached was not in USA) and they will have you send in your Leapster and send you back a new or refurbished one. I was told this a few years ago, but never mailed it in. We had an issue with it shutting off, but seems to be ok? The kid's don't complain.
SOURCE: Touch screen and stylus pen not working
I just had the same problem and found a solution on another thread on this site. Clean the screen really well with Windex and dry it. Check all 4 edges for crumbs that might be lodged in there. I found one tiny crumb. I dislodged with a small nail file (gently!), wiped the screen off and then it worked! I didn't even bother recalibrating it. When I turned it on and went to the sign in screen, it was working fine. The original post also said to try "milking" the screen in case pressure had caused it to stick. Press gently with your thumb on the screen in various spots around the screen, then try again.
SOURCE: Leapster 2 screen not working
the screen maybe dirty try turing it off and cleaning it with a rag
Hi
This is a common problem for Leapster. The company has a repair program. Charges depend on warranty.
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
