How do you remove the center bevel gear on KitchenAid Model KSM5 ProLine MIXER Solid State Speed Heavy Duty
It's an easy job but can be a bit messy since you need to open the grease-filled gear box. The following Service Manual shows all you need to know:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
SOURCE: KitchenAid 325 Heavy Duty Stand Mixer runs with low power & clicking noise
well there is a couple of things to try
1. see if kitchenaid sells the motor or
2. if a local appliance parts store can get the motor
this is the only thing you can do about the motor , the wires in the motor are shot and it will need reconstructing in the wireing, that is why it won't run fast and strong , because the wires have been heated up to much and now they can't create a strong enough magnetic field
but to replace the motor shouldn't be to hard just a little patience
if you need any more help just let me know!
electech
SOURCE: mixer will not start
The motor slides in from the rear, which in held on by just a couple of screws. I would check the brushed first to be sure they are not worn. They are the two big plastic slotted screws to either side. I have seen them actually melt from the heat as they get worn. You may need to clean the armature with a glass brush when cleaning them.
SOURCE: MY KITCHENAID MIXER MODEL # KSM5 TURNS ON BUT THE
The most common part to fail in this mixer is the worm gear:
http://kitchenaidmixerspares.co.uk/Home/tabid/36/p/Mixer-Part---Worm-Gear-and-Bracket-240309-2/ProductID/103/CategoryID/17/Default.aspx
SOURCE: Kitchenaid Heavy Duty 325 stand mixer. Making
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
