In my State a lot of my calls say unavailable if the person doesn't want their name shown for some reason. But it always has the phone number under that.
Make it available :). The Tftp ip that is programmed in the phone or passed out by a dhcp server is unavailable or unreachable. Tftp is typically how the phone obtains it's config. Does your phone work? You can access the phones settings by holding down the blue key and restarting the phone. There you can verify your settings or change them.
It means exactly that: the service is not available.
Possible cause:
You have run out of credit to make mobile phone calls.
You are trying to dial a number that has been barred such as overseas calls (if you chose that option or it is the default), paid services providers numbers (the one that charge you for services or advises) or suspended/unavailable numbers.
Consult your Cellular phone service online help/FAQ or just ring the HelpDesk for advise and/or confirmation. Hope it helps!
I think you had dropped the phone. Dont worry...The data will be there in your phone. Connect your phone to a PC.Browse all the directories(Not only just the directory which corresponds to the locations where the files where present).Sometimes you can see some newly created directories also. DOnt leave any directories. You will find it.
You need to configure your CS 1000 for Personal Directory / Redial List / Callers List through Element Manager. Instructions for doing this are in the IP Line Fundamentals NTP. You can download the NTP from www.nortel.com/support.
This is a known issue with Entrust, and normally happens if your communication via VPN is not using the IKE over TCP. Please select it. Also if necessary replace the ini file of Entrust, corruption of the ini file is known to cause the same error.
I had something similar. After trying several things, I figured out,
that the power socket of the skype box was little shaky in my case. I
had to replace the adapter, because of different voltage in Germany.
Maybe the new plug doesn't fit exactly. After fixing this, the
connection is stable again. Worth to check it.
