1394 adapter gets installed from inbuit drivers from xp , if at all you are using external 1394 port remove the drivers from add remove programs and install again
If you computer has Windows Vista or Windows 7 installed, then streaming over USB is not supported on those operating systems.
It is only supported on Windows XP.
At any rate, the quality of the video when streamed over USB is of considerably lower quality when compared to the video when transferred of IEEE 1394 connection.
If you don't have Windows XP, you'll have to find a computer with an IEEE 1394 connector and buy a Sony DV to IEEE 1394 cable. The DV port on the camera is right next to the USB port. Consult your local Sony retailer to find the proper cable for your camera.
http://www.soft32.com/download_170557.html here you will find a 1394 net adapter ...which is a driver for ethernet adapter (Lan) if you were talking about IEEE 1394...for fire wire ...this might be different
You might not of enabled it, there are little keyboard short cuts fr all the different things like your blu tooth, your wifi, your screen brightness and sound. Make sure wifi is on. Then go to control panel network connections, should be able to find it there. Otherwise it could be using software to control your wifi card rather than xp managing your wifi.
Does in system hardware configuration the network adapter show up with a driver attached to it?
Recover disk/partitions not only includes windows but all further necessary drivers for such PC then windows provides. Graphic adapater, soundcard, networkadapter.
If there is a unrecognized networkk adaptor there type 1394 you should get to know which driver it needs.
This is why I dislike Dell PC's allways. You own one, they own you together with Microsoft
I want to simply down load audigy sb 1394 driver without buying the Dr. Detective program...why can't I do this? My son gave me his old computer, but the sound card needs to be re-installed.
