Can hear stones in machine when it empties took two from filter but will others come through or can l clear it. Washes fine and spins ok.
SOURCE: fills washes rinses but wont spin properly or empty out
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
SOURCE: broken washing machine
the machine water ceal and bearings must be changed before it spoil the drum.there is small metal under washer drum to give u sine noise if the drum unstable.and if you keep using the the machine,drum get demaged.mostly all front loading machines are like that.the test is,open back cover check if there is rust on the centre shaft,that means leaking throw the ceal and bearing.open the door and try to list up the inner drum if plays means problem with bearings as above.
SOURCE: hi, my hotpoint aquarius wma42
Make sure there is nothing stuck in the pump, and that the outlet hose is not blocked or kinked.
If o/k , then you need to confirm that the pump itself is working
Select drain only. or drain and spin, and you should be able to hear the pump running, if you are satisfied that there is no blockage any where and the pump is running, but no water comes out,
Then fit new pump
Plz rate my solution.
Thanks.
SOURCE: When in fast spin there is a loud rattling sound
Probably drum bearing noise , call service agent for estimate.
You could have something fast between the inner and outer drum, or one or more of the drum paddles is loose..
Remove lower rear panel of washer, remove the belt, and from the front spin the drum by hand, this this will show if the drum bearings are o/k.
There should be little or no noise from the drum.
If it is rumbling, or feels rough, then the main bearings have failed.
If ther is something caught, then you will hear it catching or clicking.
Hope this helps.
