The power supply input jack is intermittent and needs to be repaired. If I can open it, I can fix it.
When looking at the front of the unit. The metal grill has 4 crimped tension points on top, 4 on the bottom, and 2 on each side (total of 12). Use a small flat screwdriver to gently pry them forward, I just gently pulled on the top four, starting at one end and working towards the other. Then gently lift the grill off.
Then there are 8 P1 (#1 Phillips) screws on the front. There are also 2 Phillips screws on the bottom, 1 under each of the rubbery feet.
Once they are all removed (10 screws in total) the unit simply opens in 2 halves.
Hope this helps.
