Computers & Internet Logo
A
Anonymous Posted on Apr 25, 2014
Hp dv8t 1100
How do i bypass the power-on or administrator password request that displays as soon as I turn it on?
5 Related Answers
MrARCADIAN
Arcadian Duran
  • 284 Answers
  • Posted on Jun 07, 2008
SOURCE: administrator
try this trick
when at login
hold down
crtl + alt + double tap del
type in "adminstrator"
password = just hit enter
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
ginko
Ginko
  • 19396 Answers
  • Posted on Oct 19, 2008
SOURCE: Administrator Password for BIOS lost
Nope, if you do not have the bios password, the only way to reset it is by accessing the motherboard, removing case and keyboard, and either removing Cmos coin shaped battery for one second, or bridgeing the Cmos reset jumper (that interrupts contact to battery, same as removing battery).
Lakshman P
  • 103 Answers
  • Posted on Apr 23, 2009
SOURCE: bypass windows xp login password field
hi,
Press ctrl+Alt+Delete button twice to get "Log on to windows" screen. Now give "administrator" as user name and just Enter without typing password. your will be Logged in now.
Hope this video's would help.
Thanks,
Appreciate to rate as "Fixya"
Anonymous
  • 74 Answers
  • Posted on Dec 14, 2009
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Anonymous
  • 243 Answers
  • Posted on Feb 24, 2010
SOURCE: I cannpt bypass the administrator password on my
You can remove your password with windows password recovery tool. I know a tool named "windows login recovery" that can recover windows administrator password without losing any data and you needn't reinstall windows OS. Download it from http://www.windowsloginrecovery.com and burn the program to a blank CD or a usb flash drive, insert the CD into the problem computer and reset your password to “Blank”.
HP Pavilion DV6-6c35dx Entertainment PC. How to bypass Administrator password on A pavilion dv6-6c35dx entertainment pc
See if the information and videos help you.
HP Pavilion dv6 "Enter administrator password or Power ...
HP Support Community https://h30434.www3.hp.com > td-p
May 14, 2015 - Use that code to go into the BIOS. Disable all passwords that are enabled. If asked for the CURRENT password use that code. If asked for NEW ...
hp pavilion dv6 bypass enter administrator password or power...
Aug 18, 2018
Solved: HP Pavilion DV6 - How to remove BIOS password
May 14, 2018
administrator password or power on password hp pavilion dv6 ...
Jun 13, 2016
I FORGOT MY ADMINISTRATOR PASSWORD - HP Community
Jul 24, 2018
More results from h30434.www3.hp.com Missing: 6c35dx ‎' Show results with: 6c35dx
Top 6 Methods to Unlock HP Laptop If Forgot the Password
MiniTool Software https://www.minitool.com > Partition Disk
Aug 2, 2023 - Method 1: Use the Hidden Administrator Account; Method 2: Use a Password Reset Disk; Method 3: Use A Windows Installation Disk; Method 4: Use HP ...
HP pavilion dv6: admin password - eehelp.com
eehelp.com https://www.eehelp.com > question > hp-pavilion-dv6-...
I forgot the password to an old computer I had cleaned up and now it says "System Disable 58274609" how to do this and the factory restore. I have tried F11 and ...
How to Restore HP Pavilion dv6 to Factory Defaults
AvoidErrors https://www.avoiderrors.com > restore-hp-pavilion-fac...
May 26, 2014 - This tutorial on how to restore HP Pavilion to factory defaults. ... information like Enter your Username and password, time zone, etc.
I bought a notebook model Hp mini 1104 at a storage auction . I don't have the pass word to open it up. Can I bypass it some how ?
To bypass or reset the Windows password on HP mini, you need to download and install a Windows password recovery tool. Windows Password Unlocker can help you reset forgotten Windows local administrator, domain administrator and other user account passwords on Windows 8/7/Vista/XP/2008/ 2003/2000. No damage to computer data and settings.
7answers
I need help i have forgot the power on password for my hp compaq 6720 and need to know how to by pass it thanks
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
Hp EliteBook discontinued from workplace, need bios administrator master password. Model 6930p s/n: 2CE910FDBF SERVICE TAG: E6930pUP8400W4X12MINNNN20QeS
hi!
this is how to bypass CMOS SETUP password
*open the cover of you laptop,
*remove the cmos 3v baterry.
*remove the main battery
*push the power button for 10 sec.
*wait for 5 to 15 minutes
*put back the cmos battery and connect the main battery
turn on your computer and enter to cmos setup
5answers
I have a HP Compaq dc5700, and i want to set it to default settings. I do not have any passwords for it. It has windows vista. i tried going to setting(f10) and it asks for a password. I removed the...
Password Security
Establishing a Setup password:
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down >
Restart.
2. As soon as the computer is turned on, press F10 when the monitor light turns green to enter
Computer Setup. Press Enter to bypass the title screen, if necessary. If you do not press F10
when prompted, a restart will be necessary.
3. Select Security > Setup Password and follow the instructions on the screen.
4. Before exiting, click File > Save Changes and Exit.
Restart.
3. Select Security > Power-On Password and follow the instructions on the screen.
Changing a password:
1. Turn on or restart the computer. If you are in Windows, click Start> Shut Down > Restart.
To change the Setup password, go to step 2.
To change the Power-on password, go to step 3.
2. To change the Setup password, as soon as the computer is turned on, press F10 when the
monitor light turns green to enter Computer Setup. Press Enter to bypass the title screen, if
necessary.
3. When the key icon appears, type your current password, a slash (/) or alternate de-limiter
character, your new password, another slash (/) or alternate delimiter character, and your new
password again as shown:
current password/new password/new password.
NOTE: Type the new password carefully since the actual characters do not appear on the
screen.
4. Press ENTER.
The new password will take effect the next time the computer is restarted.
Deleting a password
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down > Restart.
To delete the Setup password, go to step 2.
To delete the Power-On password, go to step 3.
necessary.
3. When the key icon appears, type your current password followed by a slash (/) or alternate
delimiter character as shown. Example: currentpassword/
4. Press Enter.
from
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00794304/c007943
04.pdf
2answers
Pc has locked itself and i do not have the defaault hp pass word to log in
bios password ? or windows password ?
if its the bios password just clear the cmos or remove the bios battrie for few mins and disconnect all power and turn the pc on it will start for a realy short second its just to clear all the power wait 10-15 mins put back in bios battrie or put cmos jumper back in defult poz and plug it back in and away u go
1helpful
Administrative password
if you can dissasemble the laptop, than try to remove battery, power outlet and small button battery on motherboard for 10 minutes and put it back, if you can't, only service is solution for you
Request
boot the computer into bios if you can and clear the administraator pasword section or just boot the computer and when it askes you for that password just press the esc key that should bypass it then go into controle panel and go under users and change the account if this doesnot work e-mail me and i will help you out more there is a lot of option here
good luck
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
