Hello,i'm having trouble with TWO new h700 headsets,when I plug them in they go straight to green saying they are charged but I can't then turn them on or get them into pairing mode or do anything with them really,getting fed up with these things now,i used these headsets a lot about 5yrs ago and never ever had problems like this,please help!!!!
Mark-
I remember this headset being difficult for people to get in pairing mode. You can find instructions here. H700 Different Paring Instructions
Mark
Motorola Support
SOURCE: Problem with Blackberry Pearl 8100
Open the boom on the headset and hold the button until it turns purple. Go to "Setup Bluetooth." Click "OK" when it tells you to be sure the device is in pairing mode. When the list of devices comes up, choose the H700. Enter passcode "0000."
The device will appear in your paired devices list in the "Setup BlueTooth" screen. Close the boom on the H700 then reopen it and hold the button until it turns purple. Click on the H700 in the devices list. Choose "connect."
This worked for me.
SOURCE: H700 connects then disconnects self
Sound like a defect, I've seen this problem before right out of the package. Bring it back to the retailer and they should swap it for you. Good luck!
SOURCE: trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and
hold the button on the H700 until the light lights up purple. Release
the button and quickly open the microphone button. The light will stay
purple and you are now in "Pairing Mode". Now follow the instructions
for your phone to pair with a BlueTooth unit. When it asks for a code,
use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
SOURCE: Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
SOURCE: i have a blackberry storm
Hold down the connect button on headset
until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000".
Now the H700 will show up in the Bluetooth device list, but it will not
connect.
Put the headset in pairing mode again, this time go to the h700
listed on the phone and select connect. Now the devices will work
as normal. When you open the boom on the h700, it will connect to the phone.
