Car Audio & Video Logo
L
Lisa snow Posted on Apr 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to see Sirius number on radio - JBL MR-17 Sirius-Ready AM/FM/CD Receiver Controller
caesar2001
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Apr 25, 2014
caesar2001
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
19568
Points
123
Once you change the radio to Sirius, change the channel to channel 0 (zero). It should show the Radio ID on the screen.
1helpful
2006 Bentley Flying Spur. How do I get or find the radio number off of it? VIN SCBBR53W76C033311
Question edited for clarity and typos.
The Serial Number is on a sticker on the back or side of the radio.
A radio / alarm installer might be able to get the serial number by using a pro grade scan tool computer.
1helpful
I have an aftermarket Clarion NX501 in my 2010 Camaro. If I want to add Sirius XM programming, do I use the original radio number on the VIN or is there a NEW radio number that Links to the NX501?
Any numbers on the car's VIN are related to factory fitted equipment only. To receive Sirius Satellite Radio on the NX501, you can connect the optional SC-C1 Sirius Connect Universal Vehicle Tuner 607SCC1 directly to the head unit's Sirius direct connection (no proprietary interface required), although this is no longer available, or try https://www.sonicelectronix.com/item_91789_SiriusXM-SXV300v1-70-Rebate-3-Months-FREE.html
HOW DO I CONNECT MY KENWOOD KDC-BT555U RADIO TO SIRIUS
If it Sirius capable, get the radio's Sirius satellite ESN, (electronic serial number), from your radio and call Sirius satellite radio and they will tell you what to do. I don't know how to get this number from your unit but in my Lincoln, all I had to do was push and hold the Sirius button on the dash with the radio on and it popped up on the display. Your instruction manual should tell you how to do it. If it isn't compatible, you'll have to buy a Sirius receiver and have it activated with them. Good luck.
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
How do I add sirius radio to my sat radio ready jvc stereo model KD-AVX11
The frst the part you will need is the (JVC KSS-RA100) this part lets you control the Sirius tuner from the Jvc radio. The next part is the tuner for Sirius this part number is (SIRIUS SC-C1)
I want to buy sirius radio but don't want any more external connections in my car for thiefs to take. Is there a chip that can be imbedded into my radio so I can subscribe without additional hardware...
No, but you can call Sirius IF somebody does take your radio and they will unsubscribe your radio's serial number, so that they can't hear anything, and it gets put on a 90day list so that the 'stealer' theif can't activate your radio.
Sirius Radio ID.. Where???
Youll have to call up sirius radio and get them to give you the number. Only if you have an account and service with them tho.
Lost ESN number in Kenwood Radio
It would help if you supplied the model number of the radio?
Thanks Leadispenser
2answers
Sirius Radio Invalid Channel message
1) Do you have a Sirius account?
2) Have you called Sirius and given the serial number of that receiver?
Those are the first two things you have to do to get a Sirius receiver working. (The original owner could have changed his account to use his new receiver, if he has one.) Go to http://www.sirius.com/install - the "activate" part - for details.
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
 Mikey
Mikey
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
